Compound waste gate
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Yeah, not looking to push these compounds to there limit, truck will be a street truck that may pull or 1/4 pass once in a while. This is also why I kept the .90 housing on the S472 for better drivability. 150's should get me to where I want to be 1,200-1,300 rwhp. My puller made more than that with 150's and ran great!
LBZ 150s?
Reason I ask is with triples and 250s I barely broke 1200hp. Lbzs flow a lot less then others.
I'm going to run my 400s with the 72/88 combo. Valley will be a .9 housing
Bdsankey
4,225
1,328
Larsen, Wisconsin
you need to sit back and learn a bit more. throwing 15 posts out each morning on different threads of half ass info does not work.
I personally disagree on this thread. I am sharing an experience on what we've done on a good friend of mine's truck with a 468/87/1.00 and 488/96/1.32 setup that worked well on that application. Truck has a built motor (stock displacement), 6480af, stage 1 heads, dual 10mm pumps, and RCD 150% injectors (LBZ). That said, we were more cautious with the way it was setup and cannot validate that a gate was 100% required.
The topic of wastegates appears to be tribal knowledge without a ton of data out there. I'm not saying I'm a genius on this wastegate topic but I do believe my data to be valid in this instance.
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Ya. Compare the flow sheets of all the trucks. Perfect example. A lly 200% will flow almost as mush as a lbz 250%. I would definitely leave the tighter housing on valley charger.
duramaxzak
Wanna be puller!
Nov 22, 2008
2,431
14
Minnesota
The LB7 injectors flow more than stock LBZ injectors, so we will see how far the 150's go. Ideally I would like 250's, but figured we will try what we have first.
