It's the down pipe lol. It's gated because that is what Nathan at MPI used to do with the original twins, before just going to a bigger housing. This is the proto type set that the LB7 jig was built for... I'm running a 1.0 housing on the 82 and have it (gate) locked completely off, builds about 26 psi and then pushes the gate open. So, needs more spring in the gate but it's fine for the stock bottom end.
Also Nathan (MPI) has piggy backed his oil off of the factory charger on all of his early kits with no issues, journal or ball bearing. I have had this plumbed this way for 50,000 miles with no oil supply issues yet... When I put the built engine in I will move the oil supply to the block, I agree it's a better place.
