LBZ: Collapsed Hose
Vrabel
TOYAHOLIC
May 22, 2008
3,434
57
Hewitt, NJ
What besides a coolant cap would cause the upper hose to collapse when cooled off? Replaced and persists.
ALLY Fox
Old Man Truck
Dec 14, 2010
434
Oregon 7S5
Replacement cap bad? Find a short piece of 3/8" rubber hose, place it on the vent hole in the cap and try blowing through it, you should be able to release the check valve easily. If not cap is still bad.
Al's max
103
Texas
I've bought a cap from O'Reilly that still collapsed the hose so went to dealer and still have the same problem. I just quit looking at it
13,736
806
did you check to make sure the vent hose isn't plugged?
GeorgiaDieselGTO
Wants to drive his truck
May 12, 2010
102
Crossville
Something to check. The plastic fitting that pushlock onto the heater coreabove the downpipe can drip into the exhaust and never hit the ground. I would go rent a pressure tester from an auto parts if you don't have one and see if you can get it to drip out any where
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,225
370
At Da Beach
It could also be pooling in the valley and evaporating. Ive seen one that was deleted doing this bc the owner uesd a hose clamp instead of a spring clamp on the cooler by pass fitting and it leaking out slowly only when the truck was hot which it then evaporated. We found it by pressurizing the system with dye...
