I have efi live..
Read the tune that it currently has and post it...We should be able to tell you if it's a problem...
I have efi live..
Kayla are you the original owner of the truck? If by chance it was bought used it wouldn't be the first time a truck was sold with a tune in it.
The truck DIDN"T throw a Check engine light but I hooked my EFI up anyways and checked for codes.. It had 2 codes.. They were P1621 P0802. I looked the codes up and P1621 is some type of ECM problem. And the P0802 is some type of TCM problem.. I have the ECM that mounts on the passenger side of motor that came with the new motor that was installed, but the mechanic didn't install it. He put my Original one back in. Should the mechanic of installed the other one since it came with the new motor? Or do I have to run the same one thats always been in the truck thats in there now? I read the stock tune off the truck also, is there anything that I should look at in the stock tune? I had to unhook the Positive cables on the batteries the other night to hook some stuff up, could that of caused the P1621? I cleared both codes and drove home. When I got home I checked for codes again and the only code present this time was the P1621... But AGAIN NO CHECK ENGINE LIGHT.. Any ideas?
Check the battery grounds since you where just messing with the cables. Matter of fact I would check all the grounds since they just swapped the engine.
P2610 Control Module Ignition Off Timer Performance
use the ecm that came with the motor. while you are checking grounds check to see if any wires were pinched or damaged in the swap. do you have the logs of it yet?
like stated above check all of the ecm pins keep at it we'll help you get up and running again!!
The thing that came with the motor is the one that bolts on the motor, thats the FICM.. Would that cause anything?
if you switch it and it continues, then you've ruled out one piece. without hearing it and from what you describe my opinion is that it is a fueling issue IF the tune is a stock factory tune. unless it is an actual hard parts problem in which case you need to start doing compression checks of each cyl and balance rates of all injectors to start and then work from there after you get the results from those.
kyle
