Cheap LB7 Intake Heater Delete
Turbotug
BEER SLAYER
Sep 3, 2006
1,019
46
Phoenix
Did you LB7 Guys notice any difference in power
I've done mine since the Dyno day, but I would bet that most noticeable gains are gonna be at higher rpms, when the engine is really moving air.
Takes all of five minutes to swap the heater out and reflash a deleted tune.
2,033
if you remove this does it hurt you when starting in the winter???
You just swap the heater element back in for the winter.
A Cummins drain plug, eh? My 22mm pipe plug didnt work, so thank you very very much for this idea!
The Autozone link didnt work for me. What is the part number, and did you snap a pic of it?
02bigstrokin
Sep 9, 2008
882
just go into napa and ask for a cummins oil drain plug. there like 7.49. just say like 2000 model i think thats what i asked for. i swear i think i could tell a difference on mine.
MarkBroviak
DMax Junkie
2,143
501
Danville Indiana
You definitely need one of these Tom. Take your heater in the store with you as there are two cummins drain plugs to choice from and yes, it makes a difference!:D
ZeroGravity58
1,401
51
Maryland
gotcha...I might do that this weekend. What kind of code does it throw? I don't access to efi live for a little while. Could I run without it or delete the fault with a predator? I'm anxious to see what kinda results I might have. Did you notice an improvement travis?
I deleted mine before i had EFI live. I wouldnt get a code until it was below 55 degrees or so. If it was warmer then that its not used and i didnt get a code.
Sep 10, 2008
1,072
Morehead City, North Carolina
Well Dustin (othrgrl) and I met up tonight, deleted the code with efi live and plugged the heater. Took probably 10 minutes. Can't honestly say that I can tell a difference; just a piece of mind. I assume it has to have some sort of restriction considering its' size. Wonder how to measure the improvements?
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
egt's might show something dont know what else . but like you said after seeing it in there it has to do something its quite restrictive .
