Casper Shake out runs
Subman
Old Geezer
Jun 27, 2008
3,233
80
Madras, OR, Pahrump NV
An 8.50 cage is like a fortress of bars, IIRC you can't have a pull out/clevis bar, getting in the seat is a bit*h without it, when you consider the 30* angle and elbow/shoulder height. The truck sits so high i'd need a ladder to get over the mid bar!! Usually you can rest a cheek on it and slide in, we don't have little ole cars anymore. :)
You sure about this? By a pull out/clevis bar I assuming a pinned bar that comes across the driver's door like the picture below? I hope that's not what you mean becuase it was OK when we built ours and It's an 8 point cage.
attachment.php
attachment.php
attachment.php
SmokeShow
6,818
Lawrenceburg, KY
This is with Dynomite Diesel injectors.
Peak RPM was 5250 rpm. This is a heavily detorqued setup, Casper makes less torque than Wendy does. Max boost was 62psi, peak EGT's were just under 1400.
still LLY wiring, ecm, tuning etc. or have you made the switch to LBZ stuff now??? :confused: If it's LLY still, how'd you trick it into turning extra Rs??? None of the tables are even able to be populated beyond 4800 I didn't think???
The Neens
BFD
4,596
Monrovia, Ca.
C'mon Mitch...Do a search for "secret table";)
2,042
Subman....what is the bright silver cylinder on the drivers door bar for? Is that the handle to "open" it? Sorry....Im cage-illiterate.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
It's still all LLY, and it does rev past 5,200. Often when you go off the end of a table, it just uses the last value.
Nothing like seeing the tach needle entering the red zone from the wrong direction... :D
Dzlnut
395
Homedale Idaho
Can EFI Live add on to the tables to tune to a higher RPM????
