Straight water, you pour it from a sealed bottle into the tank while they watch, then they seal the tank.
ok well you might want to change your water setup go with a different type more for comp use
boy Pat that makes me a bit sick just to look at it, thanks for sharing your pictures and results. If I understood you correctly you can't run compounded turbos since there are not specific regulations for diesels so they use gasser rules? Or did I read that post wrong? I got to believe if allowed compound turbos would really benefit EGT's in a long run like that.
A way to data log that will show exactly how high the temps get would be great as well. I think there is a limit currently with what EFI can do right. Isspro gauges now had tattle tail or memory gauges that will log highs or lows depending on what you are after.
My two stage Snow system did help lower the egt's. I used it in Montana when I was doing the 10K trailer one mile hill pulls. EGT's were always under 1400 degress and I was running 30% meth and an Aurora 2000 turbo at the time. It keep the heads and pistons shinny clean as well, or were when we pulled the heads due to leaking head gasket. Good luck.
BTW what is the DT class and Production class mean exactly?
Heat is still our #1 enemy.
Random thoughts in not particular order:
Water injection with nozzles as near as possible to the intake valve. Large droplet nozzles to keep the water from displacing the air as long as possible. I have heard of at least one engine that injected water directly into the cylinder. Though I don't know how well that worked.
The thickness of the pistons is no small part of the problem. The metal itself is insulating the crowns.
The cooling gallery in the pistons is a great idea as long as you can keep it filled. If/when the oil starts boiling, it will greatly inhibit additional oil entering the gallery and it then becomes a thermal break. That is, isolating the top of the piston from the bottom so you get toasty on top and cool on the bottom.
Shallower/wider bowl.
Enlarge all the cooling holes in the piston. Especially the exit holes.
Gotta say you sure know how to take them to the limit and then some. I would be proud to generate half that carnage.
Being "out of the hole" .005-.010 is fine. I normally get my pistons cut for zero deck height for extra clearance.
Yes, the pistons were coated, but they don't stand a chance against the heat we are running.
I'm going to hunt for an entire LBZ engine I think, since I "consume" parts anyhow.
This one seems like a good deal too
http://cgi.ebay.com/ebaymotors/GMC-...m14QQhashZitem120310178111QQitemZ120310178111
