Camshafts?
S Phinney
4,008
Quncy, Fl
Looking for opinions from the guys running aftermarket cams. What profiles, manufacturers, differences, etc... I have one now but is the wrong profile for the new turbo setup. I probably won't be running over 4500 and really don't want to run it that hard. Compound setup not a big single. How have the cams effected your applications? Thanks in advance for any information.
adeso
wait, what?
May 30, 2011
1,569
Minot, ND
X2-I will be looking for something this winter to help out, but I want to keep my low end power and DDing of the truck. Any merit to big cams cutting down "swirl" and hurting low end DD of the truck? or is that just extreme cams? I honestly have no clue.
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
In a vaccum situation maybe but i dont believe that would affect the swirl in a presure situation.I know like in head porting you open it up and make it more efficent flow so your boost psi goes down but your still moving the same amount just more efficently.
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
The shop truck at underground diesel has an industrial injection stage 2 cam which requires releifs in the .040 pistons. It has stage 2 so cal heads , 105 billet over a 75 billet , 125 over injectors and dual 85 pumps.... It spools the turbos rather easy and is streetable (really is). I think the cam helps out a bunch up top as it pulls like a moth f'r when the big bro lights
delong_1
<< my work
Dec 5, 2008
1,282
Arvada, CO
im interested in this also, have a socal 6460 now. since the motor is apart trying to decide what cam i should put back in it.
curt
noob
Jun 10, 2012
33
alberta, canada
i had to install a new camshaft in lb7, was lookin to go aftermarket but from what i found, it sounds like stock cam is good for lotsa power(600 + hp) but i thought maybe the sound would be different with duration but have heard they mostly just add lift(with ramp angle change)! just my 2 cents
S Phinney
4,008
Quncy, Fl
No regrind can accomplish what Im looking for. I need more LSA and you are limited on a regrind. Fuel and turbo is the main avenue for HP but the appropriate camshaft is what makes it more efficient. The picture is much bigger here than most are giving credit for. Keep any information sharing coming.
Sent from my DROID RAZR using Tapatalk 2
DMAXchris
It’s only temporary!
Apr 28, 2009
2,273
Natrona Heights PA
I'm running the Hamilton pulling grind with an s475 single, valve reliefs, Hamilton springs and stock heads. It lights ultra fast and really shines above 3500 rpm. Haven't done any dyno tuning yet, waiting for dual pumps so I'm not fuel limited at higher rpms. Works great for a DD too. Hardly any lag from a dead stop.
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Cams
I run the 8460 SoCal. It's one of the larger cams. I think for the money it's a waste! I'm not talking regrind cam's. I will spend whatever it cost but I haven't seen were there is much power if any. I also thought a cam would have to help but I just have not seen it in these motors.
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
Motors
Just for the record I fill the same way with heads! Not enough power for the money. Very little if any power differance. Spend the money on your turbo and injectors. That will make a power increase.
dmax711
Mar 4, 2011
1,057
concord, north carolina
Im leaning towards hamilton for my build. heard good things about there cams.
5,920
Here we go :rolleyes:
