caltracs
emiller3
He's Back
Feb 21, 2009
3,586
42
lake charles,LA.
What is the best way to set caltracs when first installing? I have heard to jack up the rear till suspension is all the way out the snug the bars. That eay they will load up when lowering.:confused:
Jscherbs
PIN IT TO WIN IT!!!
Oct 27, 2009
753
Canton, MI
nooo.... install, drop truck, then tighten until spring stop bolt touches upper spring and then preload it with an additional full turn.
(with you sitting in truck adjust both sides.) :thumb:
jmaz268
Lead from the Front
May 20, 2010
2,895
41
Springfield IL
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
I leave mine on the lowest hole, and with the nitto 420s tires and 20s I was cutting 1.72/1.73 all last night. Still a lot of room for improvement too.
The Funk
May 3, 2009
220
southern indiana
Yeah trent did I don't know where it is. Trent said using his chassie software to put.it.in the top hole bacuse it brings the pivot point of the truck toward the rear wich in turn keeps the frount.end planted. I have tryed both there's not a big difference but it did help
Jscherbs
PIN IT TO WIN IT!!!
Oct 27, 2009
753
Canton, MI
do higher HP applications require the use of traction bars?
i dont have a built motor and i 60ft at 1.64 w/o caltracs (clamps) and could only get 1.68 with them. (bottom hole)
Jscherbs
PIN IT TO WIN IT!!!
Oct 27, 2009
753
Canton, MI
you are a freak of nature.
i wish i could just not worry about lunchboxing my motor so i could some play with you fast guys and actually NEED CALTRACS lol
Back on topic, i thought the bottom hole was supposed to work best but i wish i would have at least tried the top < no homo :thumb:
