caltracs
madmatt
Apr 12, 2009
1,595
"the mecca"
www.facebook.com
you are a freak of nature.
i wish i could just not worry about lunchboxing my motor so i could some play with you fast guys and actually NEED CALTRACS lol
Back on topic, i thought the bottom hole was supposed to work best but i wish i would have at least tried the top < no homo :thumb:
Understatement of the year,,, nothing about how fast that truck is and still live without major issues makes sense lmao!! it's stupid:)
Dockboy
Mar 5, 2008
116
Not necessarily right on either accounts. This is the best information I've seen posted on Caltrac setup. Post #11 specifically, but some good info through out the thread. Hope this helps.
http://www.competitiondiesel.com/forums/showthread.php?t=113114&highlight=caltracs
Don't tell Pat that!... You will ruin my reputation!!! LOL
Using the adjustment philosiphy I described there and learned from from my buddy, I have been cutting some pretty good and consistant 60's for a 6900 lb. truck. Still takes some small tweaking though. The most accurate way to do it is actually to have someone under the vehicle adjusting them while under footbrake load. But that is pretty dangerous!!:rofl:
Here is a 1.53 sixty and I pull consistant low to mid 1.50's
attachment.php
A video of that pass is at 0:48 in this video
http://www.youtube.com/watch?v=TZdGRonG_sQ
Oct 16, 2008
948
12
Idaho
I was thinking about the rounds you two have went while I was posting it. I don't have time to look but I do remember something being posted to the effect of you only being on the forums to talk smack. Not for any real tech. :D
jmaz268
Lead from the Front
May 20, 2010
2,895
41
Springfield IL
Got mine on as well.....Man the oe metal sleeves didn't wanna come out, ended up having to cut mine out. Damn IL Salt welded them in place.
Dockboy
Mar 5, 2008
116
Of coarse I smoke the lights...How else could I set "record" times Jeff?:roflmao::roflmao::roflmao:
PAT
EASY DAY
Aug 21, 2011
1,100
your back yard
They are installed along with a few leafs removed. As far as settings, we will do at the track tomorrow night. :D
how many leafs did you take out? i was thinking about removing my helper spring to see if i can cut better 60's and to lower the rear another 1''. i have 2'' drop shackles...but its still a little higher than my front with the T-bars slammed.
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
Keeping sone rake,will help you with your launch in 4wd. But it really isn't going to hurt being completly level.leave all but 2 leafs in.
PAT
EASY DAY
Aug 21, 2011
1,100
your back yard
so take the helper +1 out?
EDIT: how will that effect ride comfort? i keep the caltracs pretty tight because i cant stand the clickity clack noises that they make. so the rear feels pretty tight. if i take the 2 springs out, do you think it will loosen that up?
tanlly
diesel enthusiast
Mar 13, 2010
pennsylvania
i know this is an old thread but when you take the overload spring out and additional leaves out do you use the old center bolt in the spring.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
You'll have to get some washers that fit inside the spring for more then 1 I think. They are either 8 or 10mm, thinking 10. That's to be precise, but I've seen people just use a fender washer which doesn't locate the spring bolt as well but "works fine"
zf>allison
you never had your car.
Apr 30, 2013
3,394
elsberry mo
So on a manual truck I dump the clutch off the line
I would just do the half turn of static preload? Be like releasing a brake?
tanlly
diesel enthusiast
Mar 13, 2010
pennsylvania
I was just making sure cause i was looking at center bolts I have at work and I didn't want the shank on the bolt be to long and the threads bottom out. Thanks for the help.
Sent from my iPhone using Tapatalk - now Free
