LML Callies Durastar Crankshaft Issues??
Blackmax123
683
central Pennsylvania
I am in the process of putting a new engine together now with the Callies Durastar Crankshaft. Now I’m worried and just can’t seam to win with the crankshaft issues on the Duramax without buying the billet $4000 dollar version. They all break until you get to the L5P. I hate to say it, but the 6.7 Ford is looking better everyday.
I have to agree.. Except time will tell with the l5p. The callies in my lml really does have me worried now. Since it was supposed to stay all stock while I owned it. Now with unforeseen issues it's on its 3rd engine and I thought I did it all right this time. I know I definitely can't afford to pay for a 4th engine.
But I have seen a 6.7 here at work take out the main bearings.
kidturbo
Piston Tester
Jul 21, 2010
2,552
1,401
Somewhere On The Ohio
www.marinemods.us
What is causing the increase in clearance is unknown at this point. From what we can tell(crankshaft is still in the block just in case engineering at Callies wants more measurements), the rear, upper thrust washer is taking the beating. The lower one one does not look shaved down, but over time, would've fallen into the oil pan, possibly unscathed.
Ulysses S. Grant says the crank face has a grove cut in it about like attached...
Reason I suggest you have all hardware RW tested before sending it back. That would help provide an independent conclusion as to issue at hand. Humans invented bearings because they are softer than the steel surfaces they ride against. If not, the crank would wear out before the bearings...
Don't get me wrong I totally respect Callie's and own the first 2 Duramax Ultra Billet's off the press. However on this issues I believe they really need stand up and take responsibility. Yours isn't the first failure, just the first failure publicly posted about..
13,736
806
Is that a picture of one of the Callies forged duramax cranks?
kidturbo
Piston Tester
Jul 21, 2010
2,552
1,401
www.marinemods.us
Nope another Durastar example.
I checked both my Utra Billets very closely when we had the rods out. Endplay was same as we recorded upon assembly. Only noticed a bit of wear on journals between rod bearings at bottom of stroke. At present time I've concluded that is most likely due to the Howard's rods wrist pin oiling holes lining up to journal hole in that position. Or related to the rods being cut down to fit narrow journal. Nothing to a level of concern yet, but they still seem a bit soft IMO.
The other model uses a different steel compound than OEM. This was to be the fix for breaking while keeping factory dimensions. Maybe so, but seems the hardness of surface in that thrust area isn't working out as planned.
As I first posted this could be a one batch issue that just got missed. Or could be bigger. Either way, think they need step up and let everyone know it's likely not the assembly shops fault. Ya bunch of shade tree mechanics...
Sent from my SAMSUNG-SM-G890A using Tapatalk
Duramax_9505
Oct 29, 2016
15
Crankshaft is out. Here are the thrust washers. They(Callies) say they think they have found the smoking gun, but don't want to put the cart in front of the horse. We will get a phone call tomorrow with an answer...
Duramax_9505
Oct 29, 2016
15
This is what our thrust surface looks like.
Stingpuller
The Pusher Man
Jan 11, 2007
2,019
35
central Ohio
I'm thinking there is something pushing forward. You should never have that much pressure against the trust bearing. Also unless there is a oiling problem the two metals should never touch each other. Years ago when I was build a lot of pulling truck motors others had that same problem from the clutch pressure (pressure plate base pressure plus weights at rpm). I always machined two grooves from the main oiling hole at 45* to the pressure side of the trust bearing. Never any problems even when sliding the clutch out of the hole at 8500 rpm. It could be converter charge pressure and nothing in the converter itself. What kind of line pressure is the tranny running?
Duramax_9505
Oct 29, 2016
15
It does have the EPC fooler plug so it is running full pressure @ 230psi.
MarkBroviak
DMax Junkie
2,141
499
Danville Indiana
Normally I would 100% agree with you Jeff on this as it is simple old school engine basics 101. However, this has been a single crank manufacture/design issue that has unfortunately been seen by a handful of the top shops in the country all of the sudden out of the blue. We haven't had this issue with any other cranks available including the stock one so it is pointing back to a bad batch or design/treatment issue more so than anything else. One of the ones we had this with was a 650hp daily driver that didn't make it 10k miles before oil started leaking from the front and rear main seals because of the excessive play because the lower thrust bearing fell out because the clearance opened up so much yet the bearing was for the most part untouched. The oil leak was the only reason we knew something was wrong with it, everything else was like brand new and we literally balance a new crank to it and rolled it in without touching anything else. We had two motors built at the same time with the exact same issue so it can't be a fluke. The pair of cranks were also from the same batch also ordered at the same time together.
The last time I saw an actual issue like you are talking about was years ago when a customer installed a drop box and the input shaft was too long and shoved the crank forward into the block but it only took about 30minutes to do the damage to it. On that one the crank was barely fazed but the thrust was crewed up and the block cracked at the 12 O'clock position from the force. Either way I sure hope they make it right because I'm really tired of paying for this stuff that is supposed to the latest greatest fix for our issues only to have it cost us even more money than it was worth. Other than the breaking, the stock crank has been a bad bitch compared to the aftermarket offerings that were supposed to be soo much better! So far to date, the SoCal ultra narrow journal billet crank is the only one we haven't had fail yet so I'm holding my breath that it stays that way!
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
This thread has me and many others concerned about even running this specific crank. If many other shops that you know about are seeing this it's hard to risk a brand new engine. This has my head hurting with me ready to fire new engine soon. Wish there was some way to figure out if it was a batch issue. Mine was balanced and everything.
Bdsankey
4,225
1,330
Larsen, Wisconsin
You could have the thrust surface rockwell/hardness tested. Sure you'll have to take the crank out but realistically its the only way to know based on what has been provided evidence wise in this thread.
13,736
806
Have you had a failure with the Callies ultra billet?
MarkBroviak
DMax Junkie
2,141
499
Danville Indiana
I personally haven't yet myself. On the Compstar it has been a low percentage of issue so far but as far as I'm concerned it shouldn't have been an issue period. I have a Compstar in my current race motor and time will tell on it too. According to Eric, Callies did replace both of the cranks we had issue with and it was tied to a batch that they are now saying was the issue itself.
