Hopefully someone can help here. I have a 2005 I am building with alto clutches, and when I stack the C1's I only have .071 of clearance. The spiral ring isn't installed yet, and I am using an indicator and pulling up evenly on the backing plate. My backing plate measures .440. Also the stack consist of 8 external spline single sided frictions and 8 internal splined single sided frictions. I started with an internal splined, friction side up, and ended with and external spline friction up. I was thinking the backing plate should have been .400ish which would have made the clearance check out. I can push the whole pack down about .020. Should I add that or do I need to put the backing plate on the lathe? Thanks for your help.
