Buying a truck with P0741
OleBlackyLBZ
353
85
It is difficult to mess up taking the bell housing/front drum/c3 out of them IMO. There are enough youtube videos that make that job easy (Truck Master has a pretty decent one).
To clarify, wasn't saying it to be a dick, I just don't want to see you waste money/time.
It's time to get this done, I'm going to try and order parts today. How deep should I go into this trans? I'm trying to get an idea of which seals to buy since they seem to all be sold separately.
Bdsankey
4,230
1,334
Larsen, Wisconsin
You will need the below PNs:
O-rings for bellhousing bolts: 29535578, qty 10 needed
Copper washers: 9415545, qty 2 needed
Pump body o-ring to bellhousing: 29537620, qty 1 needed
Bellhousing/stator gaskets (to pull bellhousing and stator assy): 29536478 & 29540130, qty 1 each needed
T-Case to Trans gasket: 24245110, qty 1
Reactions: OleBlackyLBZ
OleBlackyLBZ
353
85
I think I'm going to just have gm flush it, slap a LML converter in there and run it until it breaks, if it ever does... I've been watching truck masters video and I could pull it all apart but I wouldn't know what to look for anyways as far as damage. Worst case scenario is I ruin a $450 converter. At that point it would be getting a full rebuild with something better than a LML converter anyways. Thanks for all the help guys
Reactions: Bdsankey
OleBlackyLBZ
353
85
So I noticed the pan is bent up a little in the middle on the passenger side. So I wondered if it got the internal filter if that could have cause a fluid starvation issue taking out the converter. So I talked to the guy I purchased the truck from and he said when he changed the fluid and filters there was no problem with the internal filter sitting in there correctly. Ill probably put a new pan on just because but obviously he put a new filter in without issue so.. just rackin my brain
13,744
817
I know the discussion has moved past it, but here's a quick video I made about the hot flush machine. I made it because I was telling Mike about it not long after I got it. He was in the market for a new cooler flush machine, and he wanted to see how it worked. I guess he liked it since he started using them not long after.
Source: https://www.youtube.com/watch?v=ivr4zVkmISA
darkness
1,333
397
vegas
It makes a nice hand warmer too. When Mike did the trans in the ‘07, it was cold as shit that day 🥶.
