Allison 6sp: Built Transmission, now needing some help
Mike L.
15,681
232
Fullerton CA
Ok i had to validate pids, turbine speed stays zero but also stays zero when revving it up?
The front drum is not turning. Input shaft is attached to the drum. Converter splines are stripped or shaft broke.
C.bowles2
2005 lly duramax
Nov 16, 2013
489
Ohio
Here's my damage. Clean break after the splines. Not sure if i should throw in another oem shaft or do a billet input. And this makes me wonder if i should do a billet out put as well.... Id hate to pull this trans out again. Money is tight though. Time to save lol. On the upside of things i could make a nice necklace out of this broken piece haha thanks Mike L for helping me out and answering my questions, i hate bothering busy people but i appreciate it.
Mike L.
15,681
232
Fullerton CA
No converter damage. Splines look straight.
I'll give you a stock shaft; you pay shipping. Need to see back of shaft to identify it.
C.bowles2
2005 lly duramax
Nov 16, 2013
489
Ohio
Alright, thanks mike. Im gonna take some time and see how and when i can afford a billet one. Ideally id like to do billet input and output and a billet flex plate. We will see. I dont need my truck all winter so it could sit. But if not ill do that stock shaft. I have this whole gasket set from trans-tec, will these work alright or should i use superior seals?
Mike L.
15,681
232
Fullerton CA
Trans Tec is good stuff.
One more thing; Knock out the dowl pins out of the trans and install them in the block.
C.bowles2
2005 lly duramax
Nov 16, 2013
489
Ohio
Ok just did that! Haha ok im not familiar with what part is what so bear with me. Im working on getting the input out now. But i noticed the drum thing that holds the c1 steels has some wear and also the splines on the intermediate? Looks like they are curved? Here are some pics
C.bowles2
2005 lly duramax
Nov 16, 2013
489
Ohio
Also heres the end of the input mike, will i need so machine anything or is this the late style?
