So my raybestos c1's I bought back in December of 2014 do not suffer from this issue?
You're fine.
So skint.... is the conclusion that at least some of your delayed shifting can be attributed to mechanical slipping of the clutches rather than a tuning issue?
This has been a golden thread though! Reminds me of the old days!! Thanks gentlemen! :thumb: I hope Tom sees this, he's been dissappointed with the lack of technical discussion on here lately. This one fills that void nicely.
Show i would say i have found a problem with it not shifting on time is it all the problem only time will tell i should have it back up and running in about a month i sent out my injectors for some motorsports nozzles so that should give the new trans set up a run for it's money
Here is some pictures. The color difference in the c1's EX/IN were like that from new i didn't think anything of it. you can now rub clutch material off the EX spline with your fingers
That would great Andrew Thank you i will ship them out today/tomorrow. Ya'll wouldn't happen to have any Alto/kolen steels .086 would you i need 12
unfortunately i will not be able to fulfill that request on the .086 NO one has them.
IMO from what i have seen, i believe what led to the failure of c3 was a few things. Growing clearance in c1 (which has since been fixed) probably contributed as much as the poor quality of steel used in the early design Raybestos c3/c4 steels. Overpowering could have also played a factor as clearance grew, possibly poor tuning... multiple factors probably contributed. Quality of material along with coating technology has been an issue but is getting rectified and handled. This is the main reason we went full Alto steels on c3/c4 (3 thick 2 thin) VS (5) Raybestos .086 steels we were using prior to. It's getting worked out though, No one ever said being on the tip of the spear in technology was going to be easy. Send these to me and i will update you free of charge.
