Few questions about stage 4 vs. stage 5 PPE trans clutches kits.
Im wondering the difference between a stage 4 vs. stage 5? other than the obvious that stage 5 holds more power because it has more clutches but stage 4 is $200 less because you dont need the modded pressure plates and less clutches.
Does the stage 4 run cooler or hotter or same than stage 5?
Does the stage 4 shift smoother or harder or same than stage 5?
is it more time consuming to install stage 5 so that would mean more labor cost to install?
Ive been searching for awhile and cant find much info on the differences.
any info would be greatly appreciated in advance
