What's the exhaust look like? Heavy black smoke?
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Yes heavy black smoke tune one will black out a lane of traffic
Hopefully it's just the bolt that's causing the drive pressure leak and not something with the turboUpdate did find a bolt on the exhaust manifold that was backed all the way out. Could this be the issue?
What are the vanes when you get on it?
Under 1800 RPM you're really under the tq curve,
35" and 3.73 and bigger turbo make that shelf/ledge exponentially more noticeable even more so when towing lol..
4.56 would put you really close to stock, 4.10 would be my choice for DD/weekend hauler with 35" tires.
I'd definitely check the all the bolts on the exhaust side, make sure nothing else worked loose after first couple heat cycles
:thumb:
