so the plan for now is going to be accumulate parts a little at a time starting with pistons cam and crank so i can take my time and do as much work myself as possible and balance everything externally.
i do not want a 'low compression' motor so i just want to de-lip lb7 pistons which will also make the cc process a little easier since i can do it on the bench.
is there any reason i could not run 'a' head gaskets? i want to keep my compression as high as possible since this will still be a daily driver and not a max effort build
i'm around 16 to 1 at 0 deck height and running c head gaskets.I'm cut and delipped and coated.
