4-5k total. including all incidentals and such. thats my play money right now the rest i won't let myself touch. gotta have some self control lol :thumb:
i have a bridgeport and a lathe and plenty of time to learn the things i have not done. (cut and cc the pistons / key the crank and cam) as far as the block i don't know what i would have to do as long as i do this before something breaks. i think i have a source for the pistons still.
what would the motor need machining wise if i use the normal arp headstuds (not the big ones) and stock main bolts
i have all winter and into the begining of spring to figure how and if i want to do mine.
help me compile a list with prices...
rods - $2700
head gaskets - $300
ARP headstuds - $650
What sort of misc bolts bearings etc would i need?
lol stop spending my money before i make it :rofl:
rods - $2700
head gaskets - $300
If I were you I would throw a cam at her
could i get away with a simple ball hone?? i not be using main studs, just new oem main bolts. and arp head studs, will i need plate hone for them?? i know you can put them in one at a time when swapping them with the stock head bolts while the head is on but obviously i am going to be stripping the motor...
henry, have you compiled a "bag of parts" that are manditories for even a basic engine rebuild regardless of what parts are swapped in? I see you mentioned that the all inclusive master rebuild gasket/seal kit is more expensive than just buying what is needed and doesn't include the head gaskets. It probably be a hot item for you if you setup your own kit of necessities without stuff you don't need to replace.
Just a little aside that might be helpful. I know I'd certainly be adding a couple of them to my list!
C-ya
