friend of mine is losing coolant and some is ending up in the oil so we pulled the block last night to begin to inspect it and possibly do a full build and it got me in the mood to build my motor before anything catastrophically fails and damages the block.
a few questions for my lbz....
is it worth getting the gm gasket kit or are most of them reusable enough to grey rtv back in?
head gaskets, always go c grade or can i go a for higher compression?
will lbz rods hold up to everything a stock lbz cp3 and a 4094 can throw at it? most likely will not go to a 42 because i still tow with this truck quite a bit.
it it really worth de-lipping the lb7/lly pistons or can i use them in stock form?
i'll key the cam and crank and do head studs.
what else should i service in my block while its apart?
did i miss anything?
my friends lb7....
we are trying to budget build both to hold up to mild/moderate sled pulling and dd without worrying about breakage....
will lbz/lmm rods hold up to an a5k with a single lbz cp3?
are there any more reliable injectors out there to replace the lb7 problematic ones?
this should get me started on deciding if i want to build mine yet or wait, i'm sure i'll come up with more questions lol
my friends lb7....
