LLY: Build thread/Compound install
chevyburnout1
Fixing it till it breaks
Aug 25, 2008
2,368
Berthoud, CO
Thanks for the reply. I thought it was a good idea but I wasn't sure if i'd have a priming issue or if something else about it wouldn't work. Did you reattach the fuel filter head heater wires?
I didn't attach it but probably will. I have 12 volt heating pads around my lift pump which is right next to the filter. I'll probably just tap into the power feed for that and hook the factory heater back up. Never hurts when it's cold out.
delong_1
<< my work
Dec 5, 2008
1,282
Arvada, CO
I relocated the positive battery cable. There is plenty extra wire and I think its going to work good.
Some handy tools. I used the 3/8 air ratchet to take the bottom starter bolt off. The combination of extensions works really well to get it from the other side of the motor mount.
I was considering relocating the factory fuel filter to the frame rail. Think it would work?
And an update. The turbo kit shipped today:bananallama:
put that cat filter on your air dog and be done with the factory crap. jmo
shawn's diesel
Dec 25, 2014
77
Colorado
Found an old picture when I first got it moved. This was before the heating pads.
That looks slick. Nice work!
I wanted to keep it for the extra filtration
shawn's diesel
Dec 25, 2014
77
Colorado
Just waiting on the drives side charge pipe, the coolant tank, valve body, and the TCM
In the mean time I'll be fixing my power steering leak. Again.. The input seal on the gear box is leaking. Don't want to put shiny new parts in and have them get caked up with fluid
shawn's diesel
Dec 25, 2014
77
Colorado
I'm really digging the color. The intake runners and 3'' y bridge were a nice upgrade. Yes the y bridge is sitting backwards just testing
shawn's diesel
Dec 25, 2014
77
Colorado
some more
shawn's diesel
Dec 25, 2014
77
Colorado
Nice progress so far. Obviously, you have another vehicle for winter use right?
Thanks! I've been picking at it slowly. We've been using my girlfriends trailblazer and I drive one of my bosses pickups to and from work which is only a mile away. So pretty set as far as vehicles go but I need mine back for fun :D
shawn's diesel
Dec 25, 2014
77
Colorado
I had a up pipe bolt brake off in the pedestal when I was removing the turbo. The bolt didn't brake off flush lucky so it wasn't too hard to get out. Just soaked it with some lubricant and turned it out with vise grips
