LLY: Build thread/Compound install
shawn's diesel
Dec 25, 2014
77
Colorado
I've been picking at my truck for a few weeks now. Got everything ready for the compound install -removing my starter, oil pan, and exhaust front pipe. The tear down was not nearly as hard as I expected. I did twist a up pipe bolt off in the turbo though. Now i'm waiting on a package or two from SDP:D I've been doing little odds and ends. I cleaned my fire wall and i'm also going to rebuild my hydro boost, flush my brakes, clean the evap coil, and add some cabin filters. Some picture of the progress.
shawn's diesel
Dec 25, 2014
77
Colorado
A few pictures of the soot from the EGR. One of the parts in my bed.
Can someone tell me what the top bolt holds behind the fire wall? I loosened it to remove the insulation and I heard something fall behind the fire wall :eek:mg:
Also can someone tell me what the two black rectangles are on the out going fuel line?
Dallas S
486
33
Alberta
Looks good. Will be fun!
rectangles look like someone installed the super duper Eco fuel magnets....:roflmao:
shawn's diesel
Dec 25, 2014
77
Colorado
Thanks! I can't wait to get em on. Whats the purpose of them? There use to be a sticker on it that said fuel boss or fuel saver.. something to that extent
shawn's diesel
Dec 25, 2014
77
Colorado
I added some 1.5'' wheel spacers to the rear tonight. I think it looks perfect
shawn's diesel
Dec 25, 2014
77
Colorado
I got a turbo install kit, coolant cross over gaskets, thermostat gaskets, and some fender liner clips
shawn's diesel
Dec 25, 2014
77
Colorado
I rebuilt my hydro boost tonight. You can see a lot of PS fluid draining out of the weep hole. Hopefully this solves my problem. A better picture with the wheel spacers installed. I cut the EGR riser off and capped it as well.
shawn's diesel
Dec 25, 2014
77
Colorado
I cleaned up my frame and degreased what I could get to. The whole front end was caked up with PS fluid and oil. I used a combination of three brush attachments for the drill, putty knife, screw driver, and a air blower with a tee on it with a hose attached that I was blowing gas/air through.
Drivers side, front diff, oil filter, front, oil pan
shawn's diesel
Dec 25, 2014
77
Colorado
Passenger side, skid plate and cross member, some of the tools
Also an update, the turbo kit was at the powder coaters on wednesday and will be shipped out next week:woott:
shawn's diesel
Dec 25, 2014
77
Colorado
I relocated the positive battery cable. There is plenty extra wire and I think its going to work good.
Some handy tools. I used the 3/8 air ratchet to take the bottom starter bolt off. The combination of extensions works really well to get it from the other side of the motor mount.
I was considering relocating the factory fuel filter to the frame rail. Think it would work?
And an update. The turbo kit shipped today:bananallama:
shawn's diesel
Dec 25, 2014
77
Colorado
It's all in the prep work :thumb:
Looks way better
And one of the truck at a pull
shawn's diesel
Dec 25, 2014
77
Colorado
I relocated my factory fuel filter to the frame. The less under hood the better it looks I think!
Thanks for the reply. I thought it was a good idea but I wasn't sure if i'd have a priming issue or if something else about it wouldn't work. Did you reattach the fuel filter head heater wires?
