Bt Lock up box??
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
No. Going for a ride again and will try to force lock it
Just don't do it when the RPM's are low or when the trans will want to downshift. Try it in manual shift mode, 4th gear at 2200rpms or more to avoid trans damage. Remember you're trouble shooting...
LbzDMax07
179
PA
Well force lock nothing happens, no light. Auto mode blue light will come on for a few seconds at most
Hot COCOAL
Jun 9, 2012
4,433
:confused:
I'd suggest you Take it off and wait for Ben to contact you. It sound like you've tapped all the right wires, so I don't know what to tell ya. Maybe post some pics of all the connections with the BCM plugs out, so we can see the pin locations and a pic of the brake switch connection. Ben tests everything before they're shipped, so if it is the box it's be a rare instance....
CaptPhil
1,012
Delaware
It will be light green all the time. Auto mode is blue. Locked is bright green. Turn the key on but don't start the truck, the light green light should be on. Press the auto button, should go bright blue. Floor the throttle and the light should go green and back to blue when you let off.
Hot COCOAL
Jun 9, 2012
4,433
Which version do you have?
Mine has 3 buttons, green blue and red. Red is to force lock, blue is auto and green for stock/return to stock, or you can hit the previous button again to return to stock.
CaptPhil
1,012
Delaware
Same version. The lights do change. Blue is auto unlocked. Hit blue button again and it goes back to light green. Red button us force unlock. Green is force lock.
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
Dim green is stock, bright green is force lock, red is force unlock and blue is auto and locks when the throttle is at 95% or more.
FC5452
301
Eastern PA
Power ready
Auto mode turns bright green at 90% throttle
Forced lock
Forced unlock
LbzDMax07
179
PA
I just tried checking with the truck off. Hit any of the buttons and no light comes on but the box itself makes a click sound...
LbzDMax07
179
PA
And now the blue led stays on when I hit auto... Hit the unlock button red blinks but have not seen a green LED yet... Maybe the LED is toast
