I have not used fill before, but judging from how many cranks have broken in girdled, filled, internally balanced, etc etc motors too, all the extra isnt worth it
I talked to Stevie about this. While fill, girdles, billet caps, etc do stiffen/strengthen a block and keep bearing wear more even if the block itself is flexing that much, you would spin a bearing long before you would break a crank from block flex.
Either something inherent in the design and/or construction of the crank is causing them to break or from harmonics, but not block flex.
Either something inherent in the design and/or construction of the crank is causing them to break or it's from harmonics (or combination), but not block flex.
What I don't get is why there are other trucks out there running more power and not having the same issue?
i have a question.
Guy showed me how the front main areas on these motors (where the bearing would go) were bigger than most of the other main bearing areas yet we still run the same size bearing throughout the motor. Is it possible that if we had a wider bearing made to go in on the front main area and machined in the block the little tangs to hold the bearing, it would support the crank enough and help reduce people breaking cranks? Or is this not as easy as im thinkin?
I talked to Stevie about this. While fill, girdles, billet caps, etc do stiffen/strengthen a block and keep bearing wear more even if the block itself is flexing that much, you would spin a bearing long before you would break a crank from block flex. There are many truck with broken cranks without spun bearings so.... and I feel some of the spun bearings are occuring after the crank breaks and catches a bearing in the process. I've seen engines with spun bearings where the block, cap, and crank are bluer than blue and the crank has stayed together under power for a short duration (end of a run).
From what I understand there have been at least one or two aftermarket billet cranks fail as well. Were they internal or external? If internal, were they that way from day one?
I think there is 3or 4 lbs difference between the two.
Sent from my DROID RAZR using Tapatalk 2
LB7/LLY Stock 17.55lbs
LB7/LLY SoCal Super 16.55lbs
LBZ/LMM Stock 18.75lbs
LBZ/LMM SoCal Super 17.05lbs
The Super Damper is 3% smaller in circumference for a tiny little bit of underdrive on those power robbing accessories.
LB7/LLY Fluidamper 23.8lbs
LBZ/LMM Fluidamper 26lbs
I'll have to check that out when I get mine apart this weekend. if this has been the case, then why haven't new bearings been brought to the market? why market the overpriced girdles, billet cranks, internal balancing, etc etc when they aren't really fixing the problem?
