Broken Crankshaft Count?
Please pick the one that you had break
  • Total voters
    185
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
How could it be unless it was already cracked
Do you think it gets weaker and weaker before it cracks or do they just up and crack? I personally would think that having so much stress up to that point will still leave a weak spot in it. But I might be thinking to much
S Phinney
4,008
Quncy, Fl
It really depends on the material traits. Some weekend until failure and some just fail. Take 4032 and 2618 aluminum used in pistons. 2618 will take more abuse. While 4032 initially appears better but suddenly fails without any signs of failing.
countrycorey
Trust Me I'm an Engineer
Jan 30, 2010
1,512
35
LA
Yes, it gets weaker due to fatigue
Corey
zf>allison
you never had your car.
Apr 30, 2013
3,394
elsberry mo
My thoughts were it would fatigue that's why some brake as there cruising down the road. Not at a max load situation.
Dave c
Jul 7, 2013
294
I too have heard of alter fire crank failures. It does seem to be much less often than standard fire. However I know the alter fire spools slower and makes less power with a direct swap.
9,906
152
My thoughts exactly.
Already being harmonically cycled, shock loaded, etc. "X" amount of times with the standard FO which would stress and add fatigue to it would be my guess as it maybe being factor.
And those that didn't properly check or maybe didn't check it all may miss cracks just starting. Brian found a crank like this-good thing he had it properly checked.
For best results, I would suggest starting new myself.
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
This is the reason I am putting a new LB7 in my build.
9,906
152
Another "I heard of" story.
Got any proof Wade?
9,906
152
I looked into a LML. But already had a LB7 dampener and flexplate to use on it. Could now find any info on what style a guy needed for a LML crank.
From what I understand LBZ up will work. I'll find out soon enough. JD Dave did it with LMM stuff IIRC.
56taskforce
1,092
74
So if you take all 8 cylinders and have a single combustion event in each, or in other words a full cycle, does the timing vary a total of 8 degrees if comparing 2 cylinders? If that is true and then you combine the info on non equal cylinder charge according to Banks, would this be a good indicator of why the cranks, regardless of either stock or billet aftermarket break in the same place more often than not? Just trying to wrap my head around this.
It is a four cycle meaning each cylinder fires every 720° of rotation devided by 8 cylinders that is 90° between power cycles.
