Broke 12.4
CaptPhil
1,012
Delaware
That's not to terrible of a ride for me. I always like a good excuse to come over to the shore whether it be duck season, red eyes and now 1/4 mile.
I did some research and tuners can push the llys a little more than the lbzs because the injectors are bigger. I don't know that to be fact but I remember seeing that somewhere. If that information is correct, I guess I will be lucky to see 12.3 on stock sticks. I know several guys have said they have gained 2 tenths of a second with a lock up box. How does that 1058 drive? I did the 1057 which drives pretty good, and got really good reviews in the drag racing world.
The lockup box makes a huge difference if you aren't getting lockup in 2nd (which you almost definitely aren't). The difference between lockup and no lockup with my truck was about .3 seconds.
I am a big fan of the 1058. I have ridden in 1055 and precision ml trucks before and I like the was this one couples more with the turbo I have. With the stocker I didn't like it quite as much. with twins you probably don't need a looser converter, so the 1057 should work pretty well.
Michael Moore III
06 dirtyMax
Jul 16, 2013
82
MD
I gotcha. I appreciate the info man. Your truck is pretty impressive. I doubt my truck will ever see 11's even with injectors.
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
Lockup box is well worth the money!!! If you don't have it, I would invest in it for sure. Your time will definitely show gains if your current setup isn't locking properly.:thumb:
DMAXchris
It’s only temporary!
Apr 28, 2009
2,273
Natrona Heights PA
I dropped .3 just by adding a lockup box. Manifolds and up pipes wont net you much gain. If you really want to break 11s without adding more fuel, ditch the VVT and get a regular turbo.
Michael Moore III
06 dirtyMax
Jul 16, 2013
82
MD
Trust me my mind is almost set on pulling that thing out the valley. I bought on the hype. But for it bein a stock pump stock injector truck it has impressed several guys locally. But I know I can get more out of a real turbo.
bluessmax
Tabasco Injected!
Nov 4, 2010
1,154
33
Lake Charles, la
If you don't have a lock up box yet.... Send me your stock Tcm tune... Let's get it down tune only :)
*LOCKS CONVERTER**
