LB7: BPU's for the LB7
JOHNBOY
< Rocking the Big Single!
Aug 30, 2006
2,159
Saegertown, Pa
BPU stands for Basic Performance Upgrades. These are modifications that don't require engine disassembly. Here is my list of basic power mods:
1: Tuning - EFILive, PPE, or custom EFI Live tunes. To get over 500RWHP I recommend EFI Live tuning done on a dyno. Every truck is different. What dynos well on one truck may not on another. Don’t over look canned tuning as it might get you there.
2:4" exhaust with no cat front pipe and high flow muffler.
3: Lift pump - While some might be able to dyno well with out it is best to have one. It will help your CP3 live and will help you sustain rail pressure
4: Intake - A good aftermarket intake will help. I don’t care for the stock LB7 intake. I don’t care what the tests say. They dyno says my K&N FIPK made more power.
5: Gages: I recommend at least a boost gage. EGT and fuel pressure gages are nice.
6: Boost valve. Like the PPE valve can help. You want to get to 32 psi of boost on the gage. Some need the valve to get there some do not. Be careful the stock turbo will go boom at over 35psi pretty easily.
7: Auto Transmission upgrade or Clutch upgrade - The stock Allison will hate you at over 360RWHP. A good converter and internal upgrade kit is a must IMHO. The stock manual trans clutch is barely good for stock power. The Dual Mass flywheel is junk. You will want to upgrade both. Currently the only upgrades are from South Bend Clutch. A single disk will hold but for only so long. I recommend a Dual Disk.
RENODMAX
Dead Wrong
Mar 4, 2008
3,602
Lets not forget one of the many method to hold the front end together. Other than that I agree totally.:D
Noreaster
2,910
42
Cape Cod,MA
1:Tuning - EFILive, PPE, or custom EFI Live tunes. To get over 500RWHP I recommend EFI Live tuning done on a dyno. Every truck is different. What dynos well on one truck may not on another. Dont over look canned tuning as it might get you there.
3:Lift pump - While some might be able to dyno well with out it it is best to have one. It will hepl your CP3 live and will help you sustain rail pressure
4:Intake - A good aftermarket intake will help. I dont care for the stock LB7 intake. I dont care what the tests say. They dyno says my K&N FIPK made more power.
5: Gauges: I recommend at least a boost gauge. EGT and fuel pressure gauges are nice.
6: Boost valve or adjustable actuator. Like the PPE valve can help. You want to get to 32 psi of boost on the gauge. Some need the valve to get there some do not. Becareful the stock turbo will go boom at over 35psi pretty easily.
7:Auto Transmission upgrade or Clutch upgrade - The stock Allison will hate you at over 360RWHP. A good converter and internal upgrade kit is a must IMHO. The stock manual trans clutch is barely good for stock power. The Dual Mass flywheel is junk. You will want to upgrade both. Currently the only upgrades are from South Bend Clutch. A single disk will hold but for only so long. I recommend a Dual Disk.
fixed your spelling-gauges & recommend
modded regulator
A few other things that might not add any power but frees up restrictions-intake heater removal,drivers side manifold & fuel pickup
On #6 is that 32psi pre or post intercooler?
ZeroGravity58
1,401
51
Maryland
modded regulator
If you have EFI live id just put in the LBZ reg....Alot cheaper with similar results. i picked up over 2,000 PSI on the rail by switching to the LBZ reg.
fast03
1,201
60
Rancho Cucamonga
Thanks all. I like this thread since it is putting everything in one place. I am finallly gettiing more serious, and starting to build towards a dominant work stock class puller. I have alot to do to catch up with everybody it sounds like.
WanaDmaxsub
Junior Member W/gray hair
Feb 17, 2007
644
366rwhp is a predator 120 tune (On my truck). 330-340rwhp might even be a better#...
I would say 32psi measure post IC. Not sure why (could be spikes)but my SPA gauge will show a 10PSI differance between pre and post IC.
Reactions: Canabiz
fast03
1,201
60
Rancho Cucamonga
Lawrence, I am doing my boost gauge today and will go post IC. I am going to try to get set at 32psi with my bighead. I am trying to keep the turbo alive and be able to beat these california dodge pullers in the so called stock class. Getting EFI finally from Pat. so hopefully will ba able to try everything in Fontana in January
Steve
JOHNBOY
Aug 30, 2006
2,159
Saegertown, Pa
modded regulator
I just spell and Grammar checked it.:)
The restrictions you mentioned are all good supporting mods. But not the basic ones needed. I have made over 500rwhp with a stock driverside manifold, no boost valve , and no modded regulator.
32psi is post intercooler measured at the intake neck. If you have a boost valve do not measure boost from the wastegate line.
Good little write up, for the LB7 boys.
Thanks!:)
Wow that is a good gain. Honestly the stock regulator should be good. It takes a pulse width of 2800us to make 500rwhp. A healthy CP3 can easily maintain 21000psi+ at that pulse width.
ZeroGravity58
1,401
51
Maryland
Thanks!:)
Yea but with the LBZ reg im running 3150us and im holding 23,000 PSI on the rail :D: With the same pulse width and the stock LB7 reg i was between 20 and 21,000. I made 495HP and 940 torque with a stock LB7 CP3/reg and driverside manifold. I only had a PPE boost valve in with the PPE canned 350 tune.
1,866
Excellent post John. With the exact combo you have listed I made 511/999 with PPE. I have not dyno'd Nick's EFI tune yet, but I'll bet you $10 it is better than that.
My stock CP3 will hold over 23000 commanded at WOT at the strip. Id have to go back to my logs to remember any more info, and ask Nick first if I can talk about it.
IMO, this should really be a sticky in the drag racing section. Then have Pat do one for LLYs and have Henry do one for LBZs.
Jun 22, 2008
332
Nebraska
John: Do you feel a Billet Pickup or Mod'd CP3 as a benifit as well if one is on a stock motor and stock charger? I throw rail pressure codes with my 550hp tune :rolleyes:.
WanaDmaxsub
Feb 17, 2007
644
Steve
Steve, when dialin' in the boost settings do it with the A/C on. It makes a differance. With the A/C on you will see higher boost levels (I do anyway...). ...but then I also run a big tune as a daily driver...:rolleyes:
1,866
Oh really? Another good trick to know....thanks wana!
duramaximizer
#1 Abuse Enabler ;)
May 4, 2008
1,187
Edgerton, Ohio
by passing the ficm will allow you to run more pressure to the CP3 also. But you will have to find a "presidential solution" for running fuel through it to keep it cool. :D
JOHNBOY
Aug 30, 2006
2,159
Saegertown, Pa
All can help. But simply put the stock turbo runs out of air before the stock pump runs out of fuel. With more air the CP3 can support over 600rwhp.
Noreaster
2,910
42
Cape Cod,MA
you could put a tee in the supply line with a reg. going to the FICM & the other side teeing back into the line coming out of the module, probably need a check valve so it can't back feed.
