Boosted Launch Improvement?
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
You think a different converter would help? I know mine's hurting me, my 60 is about .2 slower than it was with my stock turbo, I'm sure my converter is the cause.
Harbin_22
3,858
Southern Indiana
Fluid coupling in first gear should make a big difference. They all put down power different. Very well could be the problem. I am a 100% believer in lock up boxes. I can tell a huge difference with it on and off.
6,047
A lock up box wont help lb7/lly's as much as the lbz+'s becuase you can't lock it in 1st anyway
lol thats not where the lock up box makes the difference in. I dont know the correct terminology but if the TCM sees there is too much difference in speed in the engine side of the converter vs the transmission side of the converter when not locked, it wont lock it in. That explination is probably off compared to what its suppose to be but basically, if the TCM doesnt see certain perameters met via the TC with a certain difference between the two sides, you have no lock up. i have no lock up till the top of 3rd gear or even 4th gear sometimes on the race tune due to this (well, before i had the trans refreshed, may be different now). the lock up box makes the converter lock as soon as you hit 2nd gear when your in "automatic" mode no matter if the TCM sees too much difference between the two sides. IMOP, i wouldnt want the TC to lock in 1st gear in a drag race anyhow, the gear is too short and lock up will be very hard on allison internal parts. clear as mud right? :D
