Boosted Launch Improvement?
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
I know nothing about back spacing and offset on wheels, but could too much offset or back spacing put more preasure on tie rods?
2,043
I'm sure your launch is better than this kids. I tried to tell him to drop the front but he's been racing this truck since I've been racing mine so I'm sure he knows what he's doing. Apparently he don't read up much on here. http://www.youtube.com/watch?v=FunWE-8MqE4&feature=youtube_gdata_player
What an F-n moron. He doesnt know what the hell he's doing, and puts the other drivers at risk with his stupidity. He should not be allowed on the track.
Next time you see him, you tell him I said that.
Redbowties88
Sideways > Straight ;)
Aug 24, 2009
1,943
609 New Jersey
Steve, it's not going to be easy getting that thing to hook being up so high. But there's a few things you can do to help. Is there any way you can get it lower or are you pretty set on the stance?
Next time you run pull the sway bar. Also do whatever you can to lighten it up specially from front end weight. You'd be suprised how much weight hurts you coming out of the hole like that.
If you could get a different tire setup I think some pyo's with some tires with more of an aspect ratio will really help you.. And you could probably do with more pressure then 35/25. see where the sticky is after you make a pass..if its more on the outside of the tread then the center you need more air.
Adding some negative camber will help also (not just on the strip).
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Yes, the further the rims stick out than stock PYO's the more leverage can be applied to the tie rods. + offset is easier on front ends than a -.
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
The limit straps are next, then qa1s I guess. The front is as low as it can go (bolts out). Thanks for the suggestions guys keep em coming!
Sent from my iPhone.
2,043
PSI means nothing to me. Ive always used rpm at launch. Your front end comes up far too fast, popping up like that unloads the front quickly, and you get wheelspin and the "jerking" you talk about....esp if you launch above 2200rpm.
BTW, you WANT the rear to squat some, hence the stiff front shocks, soft rear setup.
DMAXchris
It’s only temporary!
Apr 28, 2009
2,273
Natrona Heights PA
Best I can seem to get is a 1.8 60'. This is on the nitto 420 street tires, 305/50/20... Leaving around 13psi on the S472. Any higher i get the steering wheel ripped out of my hands.
Hold on tighter :D
I'm with Tom on this, adjustable shocks & smaller/lighter wheels will help a lot.
adeso
wait, what?
May 30, 2011
1,569
Minot, ND
I would try limit straps and lower tire PSI-what worked for me with a 8 inch lift and 37X14.5 nitto terras to cut a 1.77 60
adrenaholc1
Apr 5, 2011
294
Butler Co. OHIO
Different keys to lower front
Rancho 9000xl's
adjust tires pressures
control right foot
Also little preload on driver t bar. I think it was the one spinning.
adrenaholc1
Apr 5, 2011
294
Butler Co. OHIO
Looking at the rear of the truck when launching; the relationship of the axle to the frame/body goes like this. Axle rotates ccw and body rotates cw. The right tire pulls the frame down and the left side pushes the frame up which in turn looses grip on right tire and plants the left tire. The idea is to make the right side act like the left side via traction bar, anti roll bar or air bag assist on right side to help plant both tires. With that being said I dont know how the font end of a 4wd would affect or change this motion. I'm sure someone on hear could explain this better also. I think its anti squat that most drag racers go for, again I'm referencing 2wd cars and trucks.
