Boosted Launch Improvement?
adeso
wait, what?
May 30, 2011
1,569
Minot, ND
I had a lot of the same issues, read though my first run with that fatty thread-short answer T bars all the way down limit straps and tire PSI
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
I fought the same problems a couple years ago. It ended up being driver error and not my setup. I found myself hitting the throttle before I released the brakes enough. The truck would buck hard,spin the tires and tremble terribly. I fooled around on a back road some and figured out how to transition from brake to gas more smoothly. I mention this because I'm pretty sure your setup is good.
5,818
Different shocks, lower tire pressure, less weight. Get a go pro setup under the front fender to watch your suspension and what its doin
adeso
wait, what?
May 30, 2011
1,569
Minot, ND
I'm running 24-26 PSI in my front tires but they are something entirely different from you. I notice they get jumpy if I leave too much air in them
DBUSHLB7
Team DMAX
Mar 9, 2012
2,789
Albuquerque, NM
Steve I say you come to ABQ next weekend and you can test all these guys suggestions out. We have a new go pro that will be bouncing around from truck to truck all night @ the competition. Oh and maybe you could do some live "tuna" for $$$
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
Yeah the CVs are perfectly flat with the bolts out. Seems like I'm toeing more than spinning, but hard to tell when inside the truck...
Sent from my iPhone.
GeneralTJI
Turbo Todd
Jun 1, 2010
1,272
Colorado
fwiw I got 1.75 60ft with 265's at 78psi front / 72psi rear leaving at 10-12psi, old set of jcwhitney air shocks in the back, coilover setup in the front with qa1's... I think the qa1's helped.. but the track I ran at has good track prep- I think that had some real effect on it though it leaves just as hard on the street.... What's your truck weigh? Mine is lightened up, and I think that helped as well.... can the lift have an effect even though the cv's are flat?
Burn Down
Sep 14, 2008
7,092
Boise Idaho
I think Reece was down to 20-25 psi in the front tires and 18-20 in the rear... Been a year or so but pretty sure it was down in that range. From the vid I would agree it looks like your towing in a little. What steering setup are you running?
1,866
Steve, your front end is coming up far too quickly. Different shocks will help. The heavy wheels and tires do not help at all. Lots of mass there. What rpm are you launching at?
