Blackies Twins
68skylark455
Larry the "Stroker"
Aug 7, 2008
1,091
Texas
www.larrysperformancepalace.com
Got most if not all under the hood done. Still have to put in the tank and 5" exhaust. Maybe Sat or Sun I can atleast start it and drool a little:D
LarryJewell
Back with his honey :)
Jan 21, 2007
10,152
58
San Angelo
now, why not fab up a different location for the maf sensor, I dont like it being tucked under the curve of the airfilter piping, I think it should have been on top to get some airflow over it, I think it skews the IAT's because its so hot tucked in under there.
68skylark455
Larry the "Stroker"
Aug 7, 2008
1,091
Texas
Haven't looked at the wires or sensor in depth yet. In the 5 wire gas sensor I would find the IAT wires, cut them and install a IAT sensor from a different GM vehicle out in front of the filter like we did in the Ta's and Camaros to get a colder air temp, it increases timing and fuel on a gas engine not sure about a diesel yet but I will find out. You want to be the guinea pig?
LarryJewell
Jan 21, 2007
10,152
58
San Angelo
That sounds like a plan, you think you can get a used sensor............
68skylark455
Larry the "Stroker"
Aug 7, 2008
1,091
Texas
Finally got the Titan tank installed an the new Fass system as well installed last night, all new hoses, and wiring hooked up. Will pick up some fuel on my way home tonight and try to start her up. Wish me luck. Its been apart since Feb/March so I hope everything works well. I will put the tune in it when I get home and see what happens, if all goes well then I can finish the inside and it will be done, at least until we blow up the 6 yr old Suncoast and have Mike L build us a new one:D
68skylark455
Larry the "Stroker"
Aug 7, 2008
1,091
Texas
Well, it started and blew coolant on the floor:mad: not sure which cyl it is but someones not playing fair in there.:D Hopefully tonight I can get some pressure in the cylinders to find out who's going to be in time out. Sucks, said a few choice words but oh well, shit happens. I hope I just cut a cup o'ring when I put it together.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Larry this is a long shot but is your 5541 water cooled ? could it be coming from the charger if so ? Like I said a long shot but ??
68skylark455
Larry the "Stroker"
Aug 7, 2008
1,091
Texas
Its not but the GT42mag is and I have wondered about that. I think I will bypass it tonight first. I have thought that since the first time it did this. I did everything by the book this time, no cutting corners, followed the gm spec and arp specs to the letter, even spent 2 hrs looking for the right "loctite" stuff for the cups. I am baffelled but I will find it!:thumb:
