Biggest turbo for towing and racing?
DetailsUnlimited
1,264
Benton, Ar
In the market for a turbo that allows me to tow between 6-12k and still have good racing capabilities. Will be going to twins in the future so keep this in mind. Mods are in my sig and not that knowledgable about turbos yet. Please input what works for you and setup you have. Thx
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
Henry (Creatures of the nite performance) told me to run the stock turbo till i was able to go to twins and he has setups that work with the stock turbo and some other turbo sounded good to me:)
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
26
64
Norco CA
www.mcratracing.com
^ what he said ^
The aftermarket 2.6's (66mm) are good with the factory shift points to the mid 11 second range when using dual fuelers, where the rollbar rule kicks in. They are still very towable with proper tuning. An engine with aftermarket rods is not absolutely necessary, but is recommended.
The other path is nitrous with the stock charger and no dual fuelers, which can yield similar results.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
26
64
Norco CA
www.mcratracing.com
The problem with big singles has to do with actual freeway towing, which on an LBZ is done at ~1800? rpm. Big singles are very lazy in that range and the trans will hunt. You can tow with a GT42 or S475 (3.0"-75mm) if you want to tow in 4th gear. A 3.0" can be used effectively if you are willing to tow at 2200+ rpm when cruising, which is 4th gear. This is how I tow heavy anyways, and nets about 2500rpm at freeway speeds.
ripmf666
15,123
14
47
Wentzville Mo
Htt 66/71/16 ss housing is a t 3 with the gate built in. You can run the 13 cm housing for alittle better spool up but the 16 will be better for twins. If you run a 66 mm setup I a t4 setup you have no gate and if you want it you will need to add it.
As Pat said towing with a GT4202R can be done but is not fun the same goes for the Gt4094R your screaming in 4th gear. So the next best thing is the stocker with a twin kit or go to a 66 setup billet if wanted then twin off that.
LBZrcks
Jun 2, 2007
5,297
12
SoCal
Tell me bout this one. The wheel size 66mm inducer. Would a 68 be to big? Hard to spool with a trailer? Pros / cons?
Any other turbos will work as a single?
Checkout the billet 366 kit that Trent was offering. There's a thread on it here.
Now which will work for me T3 or T4? What are the differences?
T4
Whats the diff first?:confused:
T4 has a bigger inlet into the turbine side. Also most bigger turbos are T4, so if you wanted to upgrade later you could reuse the pedestal
Akdiesel
IFS Hater
Aug 23, 2009
2,213
Fairbanks
I thought big singles were so great that I could run a PBK as a single and and still tow 15k with it everyday in the mountains. :confused:
Rhall
Old Skooler
Aug 12, 2006
2,241
41
Texas Y'all
So S366, with the billet wheel. So what about the other addon's? Race cover, can i use my DE or need a new Dp? What about this batmowheel??
OOOOOOOOOOh the batmowheel... It won the florida race... so they have to be the baddest right? Oh wait, that truck wasnt the fastest there... or the 2nd fastest.... Was it the 3rd fastest? Anyways, i would wait for more testing to come out on them, nothing they have shown has proven that big of a gain. We had our local TNT, and one of the cummins boys had upgraded to the batmowheel turbo, he was ready to but his old turbo back on at the end of the day he said. Whats the price difference between the 2?
DetailsUnlimited
1,264
Benton, Ar
Not sure of the prices, But is this trents complete price? $1225 Billet S366 kit and all. Nothing on his site yet. I pulled this from this thread.
LBZrcks
Jun 2, 2007
5,297
12
SoCal
I was waiting for you to comment on the Batmowheel:D:roflmao:
GeorgiaDuramax
Enthusiast
May 5, 2010
529
Georgia
Aron picked up .2 of a second on his ET by adding a race cover, and then an additional .2 of a second again on his ET with adding the batmowheel in the race.
