LB7: Best turbo for towing and every day driver
dmaxvaz
wannabe puller
Nov 22, 2006
1,132
46
METRO DETROIT
yeah i totally agree with this. ihi's suck. i would probably get a htt also. too many people are starting to have hg problems out of 4094's. if you want the best of everything get a set of twins like trents, they obviously are the cats meow.
I wouldnt dismiss the ihi that easy! i made a trip down to south carolina last weekend, and before i left i installed a dp guage to see what it would be like with the ihi in the twin setup. all i have to say is that power is linear and the boost and drive psi were really 1:1, and it even drops almost 5 psi below boost in 5th gear going about 100mph. i am using the stock wg and a ppe boost valve on the ihi. i have also ported the intake horn, which i think it helps alot..
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Ya, that was what I was planning on. No racing for me, just towing and right foot flogging.
Htt will proably drop your EGTS 200F and give you more power keep it around 36-37 psi and the right fuel you will have a great running truck that shouldnt hurt your gaskets....I loved that turbo and thought it was perfect even towing a 10,000lb trailer
It has a waste gate built in oil cooled only so you can bypass that stupid coolant nipple that takes up all the room:D
Twins are the best bet but you pay for it also....You can always twin later when you get the bug
WolfLMM
Making Chips
Nov 21, 2006
4,005
AL
X2, HTT 66 is a good little turbo. Opt for the Stainless steel housing though! It is worth the extra coin. I love my HTT.
Turbotug
BEER SLAYER
Sep 3, 2006
1,019
46
Phoenix
Love my HTT!
Made 588HP. Well, more actually, spun the tires on the rollers.
Drags this trailer around with the "Race" tune too.. :D
Sep 10, 2008
1,072
Morehead City, North Carolina
I run the 4088 and have no complaints. Low EGT's, tows great and runs like a raped ape. I don't really regret going with the 66 htt; however, did at one time because I considered running twins. The htt would be a much easier smaller charger for that application IMO. I believe htt's are gated correct?
ChevyDieselLLY
Whats A Budget???
Apr 1, 2008
2,684
MI, NC, now Hawaii
dont worry Jonathan you can ride in my truck once i have twins HAHA
does any one have any info on the 71mm HTT? seems like it would be a pretty bad charger think it has like a .90 AR
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
i Have always wanted to try one , but have always thought the compressor was a little too close to the size of the turbine, and pretty big for a T-3 also and might be laggy as a result , if i was going to go that big on the compressor i would go GT4202
kjp800
Aug 6, 2008
525
New Jersey
x2 , MAY WANT TO HIT UP "UTAHSKI" HE MAY HAVE A SET OF TWINS COMING OFF HIS LB7 SOON , HE HAS GOT A BUILT MOTOR GOING IN SOON AND HAS A BIG SET OF TWINS ALREADY TO GO ON IT , HE MAY BE INTERESTED IN SELLING HIS OLD ONES ONCE THEY COME OFF .
edit: sorry for the caps
I thought he had an LLY?
ChevyDieselLLY
Whats A Budget???
Apr 1, 2008
2,684
MI, NC, now Hawaii
[/COLOR]
but what do you think at sea level like im at? if i could use it in by its self and then try in a twin set up would be nice. but seems like if i didnt like it i couldnt sell it to any one
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
I sold mine when I upgraded:)
I would try it,But you always want a bigger turbo:angel:
saskcan03
Oct 23, 2007
20
Maryfield Saskatchewan, Canada
Another question for you guys. What does the A/R ratio affect? What affect does the turbine wheel size have on spooling and exhaust flow?
Also, I have noticed that people only talk about inducer sizes. What about the exducer? What affects do different sized exducers have?
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
The exhaust A/R and the turbine wheel is the "motor" that drives the compressor.
If you want your boost at a lower RPM, you need a tighter housing (smaller number), but it will fade on the top end earlier. If you want good high RPM performance, go bigger.
The turbine wheel should be slightly bigger than the compressor wheel for low drive pressure. Hybrids are typically small turbine, big compressor, and normally generate higher EGT's than a more "balanced" turbo.
The bigger the exducer is, the higher boost levels in general at the expense of RPM range.
The HTT is still one of my favorite tow/track (street/strip says the gas guys) turbos. But both the GT4088/4094 are going to be good choices also.
Twins are a good choice too. But they are more $$, and a bit harder on the install.
Sep 10, 2008
1,072
if you are mostly into daily driving and street performance would you notice a considerable difference between the 1.06 housing and the .90 on my gt4088r? It still feels a bit laggy even after ricks uppipes, tuning etc....
