Best 2.5" turbo?
2005LLY
Sep 18, 2011
379
Hey Brayden or Caleb, what is my 68mm fleece capable of? I'm at 643, and have all the fuel I need can I get over 700 out of it?
Brayden
Jan 16, 2008
1,170
www.fleeceperformance.com
We've been as high as 740rwhp on a cast 68 cheetah. Having said that, the new 63mm billet cheetah rolls 735.
Give us a call, email or hit me up on fb and we can discuss it more.
dirty_max
815
eureka il
this may be a little off topic here but Ive got a question for brayden since he is in here discussing turbos. are the 71.5mm cheetahs a stock frame or a 4094 frame?
jkholder09
Jan 8, 2012
1,188
Maryland
In ITPA you can protest but you have to put up the money and if you loose the protest, the guy you protest gets the money and you loose your points. Not sure in BOB but I'm sure its close to the same.
Brayden Wow... Guess there's no saving it. 2.5 is the new 2.6.
You can point the finger all you want you guys have no one to blame but yourselves.
Hey Mark,
http://www.duramaxdiesels.com/forum/showpost.php?p=667256&postcount=6
Brayden doesn't clip wheels?
This one doesn't have the smooth edge like in the model he showed.
I guess I am still confused over all this:D
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
A bead blasted billet wheel to make it look casted is against the rules. But plenty of shops offer that! That's no grey area! Everyone's gonna be accused of cheating, just gotta do your own research and not believe only what you find out on the Internet!
carpenca
Dec 17, 2010
168
Hey Mark,
Well what you have there is a old 2.6" Clipped Protrusion turbo. Common in most National 2.6" organizations. That one actually built by ED. This is a thread concerning 2.5" turbo rules, that clearly states NO CLIPPED WHEELS.
The Definition of "Clipping" a wheel is taking a wheel out of a box from a manufacturer and either putting it on a lathe and cutting, or grinding the inducer down to a smaller demension. This method is used to either make a perpendicular step like you have there in order to meet 2.6" or 3.0" Protrusion rules. Or "Clipping" could be used to make a drastic change to the profile of a wheel in order to make a big wheel fit into little wheel rules.
Now nowhere is there a stated Exducer limit, mainly because it would be hard to tech. So changing the profile of a wheel that meets the set inducer limit, and adding a larger exducer is not illegal. Its taking advantage of what you have.
For all reading to understand, the Exploited Grey area in this conversation is defining whether or not the wheel has been "Clipped" or is just made that way. Its a matter of interpretation which is why it has been so heated, and hard to discern. In order for it to be legal in 2.5" it obviously cannot be a perpendicular step like 2.6". But does that mean adding a drastic or exaggerated downward "taper" is legal, as long as it has 1/8" protrusion of a 63mm inducer? This is the question (not an accusation), and where those that be need to come together and address the rules so it can be better defined and clarified.
FPE's Comp 2.5" Compressor is derived from a Holset based profile, which is a pyramid type wheel, that naturally never protrudes square into the bore, unlike a Borg which does. This is the case from Holset HX35's to HX60's and beyond. FPE took extra steps in order to make it legal for the 1/8" Protrusion rule for BOB & ITPA, in which case it actually has almost 3/8" of protrusion square into the bore. The wheel comes out of a box from the MFG and onto turbos. No other modifications are made. Its used because it is FPE's proprietary design developed over the past two years, first with the Holset HE351 Cheetah, and now used in the entire line of Billet Cheetah Turbos. It has helped us further advance the capabilities of the entire line, and can only be bought from Fleece Performance.
Caleb
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
If a wheel is blueprinted and manufactured the a super back verus being modified, what is the difference of the end result? Danville wasn't the first to cut one, probably the last. E.D. And another company have both done it. Or had serious plans of it before. Ill be in the market for a new charger because I am playing catch up with trucks already equipped with them.
jheyob
305
Okeana OH/West Lafayette IN
What do you mean an actual tech? They have teched all the trucks that have showed up. Not every time but atleast once. Atleast when Chris is there. He's had a rough few months, more deaths in his family then I can count. So he hasn't been able to make but half the pulls
No, not a single truck had the charger teched at the two bob hooks I've been to this year. There are 2.6 truck(s) that have not been teched once this entire year other than hitch height and weight.
carpenca
Dec 17, 2010
168
Also can somebody please explain to me what a step down cover is? Is that to fit that compressor in the link posted?
A stepped down cover is a result when you clip a wheel. If you were to take a cover off a turbo, and run your finger from the inducer bore to the exducer without lifting it, it should be a nice smooth transition from start to finish. With a stepped cover you would feel two distinct bumps as your finger fell into the "step" and came back out.
Typically the step is done in conjunction with the MWE groove, so that the "Clipped" section of the wheel can pull air thru the MWE groove.
All that said, when we modify OE style turbos, and machine the covers for the larger wheels, the MWE groove changes due to the casting and the material being removed in a way that could also resemble a step. So common sense has to be used if you were looking for one.
Caleb
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Okay so that's just the correct term to use for the cover on a clipped wheel? I always got confused before they say both no clipped wheel or stepped cover. I originally thought a step cover was a bushing welded in with no wheel protruding into the bushed bore. I was wrong.
Btw an Ohio truck running the street class lastnight got teched after putting it in the sand.
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
carpenca
Dec 17, 2010
168
That would also qualify as a stepped cover...
Caleb
2005LLY
Sep 18, 2011
379
So the rules are out, it's a smooth bore true 2.5 turbo with stock map groove, what would be my best bet? Twin cp3 are allowed and I have 100% injectors.
