Beginning of the end?
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Not sure i understand the question? Live? Work? Hang out? :confused:
He's building what sounds like some very nice stuff for the near future.
James he is a Alberta Boy:D Just being my normal smart ass self:eek:
Btw i never noticed your typos untill you said something:rofl:
and NO i dont give a shit!
MAXLLY
No Lemming Here
Aug 15, 2007
1,063
San Diego
DOH! got me, he mentioned Wisconsin?.... but dat's not Alberta... Alberta is WAY colder!:rofl:
i before e except after c excepts......
Anyway, back to topic. You will love the oil pump, it's a nice part. Watch the clearances between the cam gear and the front of the unit they are tight. Don't drop the gear it could/would wobble and hit the face of the oil pump. ONLY if is was bent/not flat. There is enough thickness in mat'l to cover ya, but still...the finish is so nice.:)
MAXLLY
No Lemming Here
Aug 15, 2007
1,063
San Diego
It could if i took next week off work... can't do that. I have projects now.
Hood looks good huh! Will you take the intake over to Mike?
Slacker? Dude I was at the shop before you even went to bed.:D
MAXLLY
No Lemming Here
Aug 15, 2007
1,063
San Diego
Status.
I have all the parts required to assemble the motor. Had a fit problem with the rod/piston last Saturday, Guy swapped me out Monday and sent me down the road, fast and efficient as usual. Check the small end width when using aftermarket rods with aftermarket pistons. No big deal, it just stops you cold!
I calc'd a bad number for the fuel tank... 1 gallon of fuel is 231 cubic inches. I had my tank drawn as 36x24x12... that's freakin' 44 gallons:eek:
Plan for the next two weeks is build the motor, install it, pull the cab back off and run the balance of the lines (air/water/IC/oil/fuel). Unless i come up with a better idea i will probably run a short exhaust stack passenger side and finish it black (the interior of my bed is black), maybe 17" tall from bottom of bed to top of stack. My wife follows a diesel truck (w/ stack) home and claims the smoke flows over traffic versus into it.
Found a 12" and 14" slick that rolls out the same for 4 wheel drive, M and H.
Hood turned out really nice... so nice it's almost a shame to install it next to factory GM paint.
