BD Intercooler
Dave at BD Diesel
Oct 7, 2008
87
:cool: i will get one eventually ....
I have member pricing available through my distributors when the time is right contact one of my vendors that participates on this Forum and they will get you set up with the forum discounts. There is some vendors already on this thread.
Nice turbo and pipes BTW, looks GREAT!
Leadfoot
Needs Bigger Tires!
Dec 27, 2006
904
31
Western MA
www.matpa.org
When the 06's become available will they use the stock CAC tubes? Just wondering if the outlets are bigger than stock and if upgrading the tubes would help. If so, who sells the tubes that will work with this unit?
Thanks.
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
You will not be disappointed, let us know how it works!
Have you got the drivers side full bore manifold installed?
I did until I went to full headers and up-pipes:thumb: Do you guys have anything else you think I could use?
What is the limit of the stock intercooler?
I have an LLY and it will be seeing 40-50psi soon.
I pushed 40-50 for a year before pushing it over 60. Not long after going over 60 it started leaking. Some people have problems at 30, others claim to not have problems with over 60. My recommendation is to test for leaks, especially if you see a drop in boost or start running slower times with no other changes to the truck.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
I agree , i never knew i had a leak, with my twins i didnt even see a drop in boost . I didnt find out untill i sold it to a freind of mine , dont know how long it had been leaking but it was .
Dave at BD Diesel
Oct 7, 2008
87
feedback
Hey guys, we are working on some new intercooler tubes for our Duramax Intercooler kits... where are you guys seeing the majority of the boot failures; lowers, uppers or just all of them?
Trying to keep cost competitive, if you had to replace only two of the boots which two would you replace.
We will likely offer all of them but are looking for feedback form the gurus!
othrgrl
Mar 10, 2008
2,151
Wilmington NC
I would like to see you offer 3" boost tubes similar to what banks does, it would really help sales too. I would prefer if they were configured to use straight boots at all locations.
I blew out 2 of the bottom driver's side boots in one night when I had the stock intercooler and another a few days later. That angled boot didn't like the boost. If you could make the bend be in the tubing and have it use a straight boot there, that would be great. I had to cut my driver's side Banks tube into 3 pieces, reconfigure it and add about 4" total to it to get it from my S400 to my intercooler with a straight boot on each end - haven't had an issue since. Best part about using straight boots everywhere is if I blow one I cut the length I need off of a long piece of straight 3".
Also if you make the tube right you would be able to use an LB7/LLY intercooler in an LBZ by simply using a different passenger side tube - no need to redesign.
ChevyDieselLLY
Whats A Budget???
Apr 1, 2008
2,684
MI, NC, now Hawaii
x2
zfuller123
StarLite Diesel
Sep 2, 2006
429
Utah
www.starlitediesel.com
I have had 1 problem with driver side boot and Banks pipes, and keep having an issue with the way the banks pipe / hose come off the charger in the factor spot. Keeps slipping, so i clamp it down harder that then bows the end of the boot... i'm on my third turbo to tube boot, and 2nd lower boot.
I too would love to see a tube with as casual of a bend as possible, but to allow for a straight boot going into the intercooler....
othrgrl
Mar 10, 2008
2,151
Wilmington NC
i would also like to see a driver's side tube that will work with a S400 or GT42 turbo, that would save a bunch of time :thumb:
Only problem with that is it depends on spacing, pedestal, and compressor outlet type it wouldn't be a one size fits all deal. If it was a 2 piece driver's side pipe with a silicone coupler long enough to accommodate from stock up to an S400 sitting about as high as possible, then it would be great for everyone.
Either way you can cut it and weld in an extension or roll a bead onto each side and use a silocon boot.
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
if it was made for the GT42 or S400 as if it was sitting as high up as possible without hitting the firewall, then any modifications for lower pedistals would be simplest and only require 1 cut and weld
Dave at BD Diesel
Oct 7, 2008
87
That's why I asked here... Thanks a lot othrgrl, that really helps, if we can keep em on your rig we should be good across the board!
Banks advertises that our intercoolers flow better but play on the fact that we do not include tubes or pipes, I am sure that is part of the reason we are looking at them. We have seen an large increase in demand for the boots lately... GM shortage on OEM???
othrgrl
Mar 10, 2008
2,151
Wilmington NC
Not sure about the demand for boots, but like I said having the tubing made to eliminate the need for angled boots would be awesome for racers and pullers. We could carry one long piece of 3" silicone and cut off what we need to replace a blown boot. And they are less prone to failure in the first place.
Dave at BD Diesel
Oct 7, 2008
87
make sense to me... R&D is saying that it completely doable so i expect that's the way we will be going. I will keep you guys updated.
Thanks again othrgrl!
