LBZ: Banks Speed Brake
Jasondt2001
May 3, 2008
373
Salinas, Ca
That is one sweet lookin Jimmy on the cover of the Mag:D
You should see it IN the mag - The damn thing looks like it was borrowed brand new from the showroom for those pics... it made me SICK :hug:
I see you said 50=100% vane and only 5 - 6 lbs of boost pressure?
The highest I've logged is around 10psi ( on the gauge ) I also saw in that article something about safeguards so you won't float valves... That's interesting, any thoughts? I sure hope I don't float mine, I've had it for a while now with no issues... Knock on wood.:rofl:
sqdd51
Bad Ass Duamax
Nov 7, 2007
14
Palmdale CA.
I'm assuming (that we should never do) that when it shows 100% braking the vanes are completly closed. I'm not too worried about valve float with the brake when I run 32lbs of boost just jumping on the freeway.:driving:
13,746
821
Valve float is more of an RPM related problem. As long as you don't pull too many RPMs, you shouldn't have a problem. Since the stock trans brake pulls the RPMs well over 4k, I think you'll be fine.
Jasondt2001
May 3, 2008
373
Salinas, Ca
Thanks fella's, I value your input, it puts my mind to rest!! :hug:
sqdd51
Bad Ass Duamax
Nov 7, 2007
14
Palmdale CA.
Your right on valve float is usually the result of high RPM's, I don't think the stock cam profile is going to be a problem with valve float as you said under 4000/4500 RPM. 50 lbs of boost might try and lift an intake vave off its seat with a stock valve train but I dought anyone is running a Speed Brake that can do that. I think every one should be pretty safe with it.:driving:
