banks billet flexplate vs Ats billet flexplate
jdlover1
437 Cubic Inches
Oct 4, 2006
538
chapanoke,nc
I have been told the samething that the hp level the stock flexplates can take have not been defined yet. I would like to use my stock flexplate to save money on the build but i know my luck and mine would be one of the few that breaks
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
Casper has never broke a flexplate. Just an FYI :D
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
i know of 3 people personally and the hp levels are 700 and other 2 are 800 hp trucks none of them have broke flex plates . but probably a good part if you have the coin .
durallymax
Apr 26, 2008
2,756
Under The Hood
i know theres guys over 700hp running stockers, then theres the truck in my shop thats about 450hp maybe with an ATS 5 star that ripped the flex plate and a chunk out of the flywheel.
Subman
Old Geezer
Jun 27, 2008
3,233
80
Madras, OR, Pahrump NV
Ugh. Wonder if I should add one in with the motor build.
Question is, which? If ATS only works with 5 star, and Banks isnt out yet, and Opies isnt exactly proven.
When you building? Mine is going in within the next month. I'll let you know. If it's like the rest of Opie's stuff it's bound to be pretty tough.;)
Micheal Tomac
been pulling forever
Aug 12, 2008
273
MI
The ats billet flexplate/flywheel should work with any Allison converter, you just use 6 of the 12 holes.
9,906
152
I thought I heard/read something somewhere that you needed to use a different bolt when you use a PI or SC converter with the ATS flexplate/flywheel as the depth of the mounting bolt hole in the converter is different. Or was it the thickness of the flexplate/flywheel was different-I honestly can't remember so I may be out to lunch on this.
Did anyone else hear/read this?
jpowel29
780
Bentonville, Arkansas
I have used the ATS flexplate with both a Goerend and Hughes converter. You will not be able to use the ATS supplied converter bolts. You will need a different thread and the bolt will need to be longer to compensate for the extra thickness. I think it is a 12mm x 1.5 bolt (going from memory - I have a bunch in the garage so I will look tonight).
15,681
235
The thickness of the flywheel ( ATS ) is different and requires a longer bolt.
SIKDMAX
Highway Burnouts!
Sep 14, 2007
4,698
Central Coast, Cali
www.sikdmax.com
But it will work Mike? (ATS flywheel with SC converter)
Im somewhat worried about my stocker and since Guy is doing everything else to make this the end all be all build, thinking I shoud add a flexplate.
