I have been running my exhaust dumped for the better part of 6 years and have not noticed any problems with soot on or under the truck.
If you're putting soot on the trailer now, a dump will still put soot on the trailer, it will just spread it out across the front of the trailer. If you are lucky, most of it might go under the trailer, but I suspect you will just end up spreading the soot, not eliminating it.I was thinking of dumping my 4" flo-pro just behind the axle, too. I pull a trailer all the time and the right side gets pretty sooty. A dump would help it to stay cleaner, right?
Had mine dumped just over the rear axle since 2013, its a 5in flo-pro without the last section on. No soot on the truck and I haven't been turned away from the track. Drone isn't that bad either.
Mines a 5" MagnaFlow and it didn't drone. It did add vibration to the cab and bed.
It will have a deeper tone.How does that Flo pro sound? Is it straight piped. I have 4in and after the new turbo install its a little raspy at higher rpms. Will 5" help out.
