Aftermarket IC pipe, manifolds, up pipes, even an aftermarket intercooler? I see lots of guys have it done..but at what point in your build do you stop and say its time for this stuff..? At what point is it absolutely necessary?
Very well put!
Thanks
You sir, might be the only one who will read that monstrosity :spit:
So you are very welcome:hello:
Sorry guys, that post started as a two liner
Good info! That's what I was wondering..so I'm at that point right now...475/stock, built trans, studded, some pretty nasty tuning, traction bars....all my manifolds, up pipe etc is all stock..so it'll be the logical move to invest in a intercooler? Before I go back to internals at all?
I don't see a lift pump in that list?
That would be my next move if you don't have one already. Also, I ran new larger fuel lines front to back and removed the factory lines then I modified my fuel pickup in the tank. I deffintitely saw an improvement in my rail pressure after all that.
Also get an LML drivers side manifold, they are cheap and effective...
There is ZERO reason to upgrade your intercooler unless you are pushing over 55 psi of boost...
Ya fass 150, 5/8 pickup, I'm already @ 55lbs of boost
Oh
F yeah man, get an aftermarket intercooler
I would've changed it out before 50psi, just to be safe, but that's me....I'm not a fan of "finding" breaking points
BD
Mishimoto
Banks
That's my top 3 choice list in order...and at that boost level, hells ya, I'd expect a pretty nice difference in several areas with an upgraded intercooler and IC hot/cold pipe, I still wouldn't spend the money on manifolds, yet, but if ya just gotta have a set I'd get HSP's
I didn't see any dyno gains from up-pipes and drivers side manifold. The few that have tested it back to back and said they do make more power were drag racers, I think. I also didn't see any peak EGT reduction with a banks I/c, but it probably took longer to get to peak. This was all on a 600rwhp LLY.
Haha ya..thanks for the info!! That's what I'm looking for..I just read a lot about guys getting those upgrades very early in a build, some don't till further into it..some don't at all. Its hard to find real numbers on any of it..aside from the ic. But besides that are there any real life comparisons on a truck with aftermarket manifolds and up pipes vs stock flow? (Stock or aftermarket charger)
Is that typical? EGT's are comparable to stock on a aftermarket IC? Is the real benefit in upgrading the IC because it can handle more boost ? Or for egt's/flow?
