What is the airspeed velocity of an unladen swallow?
What kind of Music do you like pat? And is it possible to beat Mike Dilhennay with our setup?
Stupid coconuts.
But it's certainly faster than the unladen speed of BiGpOwA's Ford 7.3.
If you can answer this question then I will finally know everything as you once did.
How many licks does it take to get to the tootsie roll center of a tootsie pop?
Hell, I'll give it a shot too.. What is the over kill psi of a LB7 Turbo? I've heard anything over 28psi is overspooling.. I like 31psi..But!! I ran 24psi just guessing adjusting my big head that GM F-ed up and it ran a 12.9
heres a good one-
does advancing timing create h/p and kill torque
in an otherwise stock lbz lets say i want more h/p and less torque output
other than increasing rpm how can i?
So Pat, Does higher boost = more power,or O2 on a LB7 charger, or am i overspooling at 31? That's the ? of the hour I know i'd kill it at 36 or 40psi..
So Pat,
If the speed of light is 186,000 miles per sec and you are driving your truck 68 mph and turn your headlights on; how fast is the light beam going? :baby:
186k miles per second, relative to you, because your velocity distorts your timebase.
But if find the right hidden tables, you can actually catch up to your headlight beams I've heard.
Yes it can. With a faster vehicle...lol
