didnt think so. Whats my cheapest option? I dont really want to buy a 150 dollar gauge to check the pressure once.
If you threw a code without getting any fuel in the bottle than the FPRV is fine and should be left alone. The next thing to check is positive pressure past the factory filter. If you don't have pressure change your fuel filter(s), if that doesn't help than your lift pump is suspect. If you have positive pressure then you are just demanding more fuel pressure than what your CP3 can keep up with based on the PW you are asking for and to fix it you will have to either ask for less pressure or less PW - typically keeping pressure above 21,000 is best.
He is runnin the ppe level 6. You think with the shim mod and lift pump that the cp3 still cant keep up with the PW in the level six.
You can purchase the adapter to go from 10mm to 1/8 NPT here: http://www.glowshiftdirect.com/18-npt-female-to-m-10p-15-male-adapter.aspx
Man, I'm sorry, but I just found out the other day that the link I gave you is no longer any good. The screw in the filter housing is 10 mm x 1.5 pitch, which is what the link is supposed to go to. Unfortunately the company must have stopped carrying that particular adapter, and instead of being a bad link, they redirect it to an adapter that is 10 mm x 1.0 pitch. The only other place I know of to get the correct adapter is here: http://lubricationspecialist.com/front/shop.aspx?catid=10&parentid=0&productid=42 The good thing about it is you can get a T-fitting so you can use the needle valve and still have a spot to screw in the sending unit.Got the adapter in. Where am I supposed to put it? There is no way it goes where the bleeder screw is. The threads are completely different. Thanks in advance.
Really hoping someone can chime in here. Fuel filter still has roughly 70% life on it. No leaking WIF sensor. What about a small leak on the engine side of the lift pump? There is a drip on one of the fittings that doesn't seem to leave any puddles on the ground, but there is always a drip "chillin" there when I crawl under there and check things out. Is there any way this could be causing issues?
