So the hose going into the bottle should be hooked up to the fuel rail? And this wont blow out at 20,000 PSI? Sorry guys, i'm trying really hard to understand how the fuel system works.
Yes, the hose that goes into the bottle is hooked up to the fuel rail. That hose is actually not used for the majority of the time, only when the FPRV lifts will anything come out of there.
And yes, it may come out at 20,000 psi... but by the time it passes around the FPRV and goes through any length of hose it will have lost pressure.
grab a small fire ext. if you want to be on the safe side
When you took and out for the bottle test did you rip on it and throw your fuel pressure code?
