yeah my trans is built sorry i havent filled out my sig yet.
trans consists of ATS triple disk, ATS pump kit, alto clutchs, transgo, Allison deep pan, amsoil sythetics. tuning im currently running a TTS extreme and have holley lift pump. actually just finished putting the engine back in and got it running tonight. about a month ago i kept getting low coolant light.. long story short my head gaskets let go. so i just got head studs put on as well. (so dont need to worry about those either) also a brand new (very low hour at least) stock turbo because mine was about ready to fall apart. <-- i will blame that on using a quadzilla monitor gauge which reads boost from the computer, which i just learned last week isnt accurate past about 30 psi! and running a ppe boost valve and have been having quite a bit of fun the last 4-5 weeks since i built the trans. so i pushed the stocker past its limits! so i got a very lower hour turbo from tony burkhart i figured thatd be my best bet if i plan on going twins to keep the stocker.
im not looking to take it to the drag strip or anything, but i'll be the only twin turbo d-max around the area that i know of which is cool and it will make towing my toy hauler and buddys pulling truck really fun
but all in all would that turbo i suggested be a good setup do you beleive? i plan on doing a build similar to the one that a guy did on here cant remember his name but he has about 7 page long thread in the turbo talk section about his setup he made. so i plan on putting turbo over fenderwell, going to get rid of fuel filter on valve cover and just run a fass setup or a cat filter on the frame rail. move battery to frame a coolant tank back to firewall.
im hoping that as long as i keep single CP3 and get the tuning dialed in good i shouldnt have to worry about rods or pistons....? but who knows i guess.
