Mine don't rub, I have a 6 inch fabtech with 35s.![]()
The wheels they were running were Mazzi Hulks that stuck out pretty far.
Yours rubs because the fabtech lifts increase the front track width and make it rub more. My cousin had a fabtech 8" that rubbed with the same wheels and tires as my dad's truck with 6" RCD and no rubbing.
Sweet,Thanks all!!!So I guess 35's will work as long as you have a positive offset. I'm ASSuming positive offset means the wheels are offset towards the outside of the fender well??
If so, should I go with 315's or 35x12.50's?
Also, I was looking at the new BFG KM2, which are pricey, but have read really good things about them as far as tire wear, and the easibility to balance. Any input?
Nothing to do with the lift kit I run on the truck. I run wheels that have a lot of back spacing or negative offset. Thanks![]()
Um that fabtech you have on the truck sets the track width out alot further than most lifts which is like having an extremely high neg offset which paired with a neg offset rim cause them to stick out of the fenders a whole lot and rub quite a buit too.
My buddy has a Pro-Comp Lift and it stick out 5/8" farther on each side than my Fabtech does. His doesn't rub either with his 35x12.50/16's.
No 305/70They have a 305/65 that's 32" tall:jerkit:
oh, I forgot
If I can get a 39.5 under a truck with a 6" kit...........I'm pretty ****ing sure you can get a 35 under yours.
