anyone know whats going on with sikdmax?
RPM Motorsports
smokinum
May 13, 2008
3,271
Central Valley Ca.
in the two upper pans i have drilled and tapped for a turbo drain; i used a 90* drill ,overfilled a quart or two, and used a shop vac to suck out the shavings / extra oil. neither motor had any bearing or oil pump problems.
Wich is the exact way it was done, just like 99% of people twinned have done. That is a crazy amount in the pan, since most say the excess oil pushes the shavings out!
HEEPJEEP
<--- Solid Axle "Leveled"
Mar 26, 2009
136
NH
I did mine this way, when I dropped my pan there was easily the same amount of shavings in mine. I won't be taking that "short cut" anymore and always pull the lower pan (but I weld a fitting on the lower pan instead of drilling).
ChevyTruckGuy78
Twins done Now for trans
Feb 7, 2010
694
Ct.
drilling
thats an idea i gotta do mine still and that might work for me
quadracer37
Mar 31, 2009
547
northern, IL
the first time i did mine i drilled and tapped with oil in the engine still. 7 months later had the pan off but didnt have any amount of shavings like that.
but i did like heep jeep mentioned and i welded on fittings to the lower pan for the new engine build. my upper pan always had a slow leak that was annoying.
quadracer37
Mar 31, 2009
547
northern, IL
yeah, i had a bunch of pics of it over on the DP.. probably shouldnt be posting up links to another site here though, ill start a new thread of it on here i had meant to awhile ago just never got around to it.. give me a few ill get some up in a new thread here
