If you and I did not have bad luck we would not have any with these trucks Hang in there man, your getting close:thumb:
Is this something PPE did?
Its the Dye used to find where the oil leak was coming from. Thank goodness it had a leak or this would not have been found till more damage was done!!!What the **** is it green for?
He's very close!!!If you and I did not have bad luck we would not have any with these trucks Hang in there man, your getting close:thumb:
unfucckin believeable
im sure its definitely is going to leave a bad taste but now its DONE and hopefully you will enjoy it :thumb:
Those would be shavings from when the twins turbo drain was drilled - with the pan still on the truck. The pan wasnt removed, .
Matt do you have any idea what is involved in removing the upper oil pan??? You're saying it as if "he was just being a lazy idiot, anyone else would have pulled the oil pan to drill it"
Do you know how many people drill their oil pans for twins with the oil pans still in place and never have a problem????
And finally, for anyone having a heart attack about the aluminum (read: soft/not gonna wreck anything) metal shavings. Are you guys all forgetting these engines have OIL FILTERS?
Ben,
You feeling ok lately???
Who said the upper pan needs to be removed??? Anytime we have drilled the the pan we remove the LOWER pan and remove any drill/tap shaving from the engine. Make sense???
If I remember correctly the oil filter is AFTER the oil pump. Yes the oil pump has steel gears but the housing is aluminmum. Did it cause damage? I dont know!
The way I read your post it seems like you are condoning what has happened? Is this true? Are you NOT seeing a pattern here?
Better yet bring YOUR truck by the shop and I will put a handfull of "soft/not gonna wreck anything/Aluminum" in your oil filler tube. I wont ever charge you...:roflmao:
Do you know how many people have drilled there pan without removing it????.
you guys cut the filter open?
Your truck is done come pick it up!!!! Leak is fixed, oil is changed and filter replaced... The old filter looks good (when we cut it apart)..:thumb:
