Anyone 7.3l smart?
WVRigrat05
Wound for sound
Jan 1, 2011
3,081
French Creek, West Virginia
Have a friend with a 2001 7.3l 6 speed.
Banks 4", banks wastegate, 100% stock, has 35's and that's it.
When he starts it of a morning, it puffs heavy white smoke and misses, when it warms up it runs fine. No fuel in oil or antifreeze mixing anywhere.
Anyone have an idea what to look at? I'm thinking a sticking injector but I know they run off the HPOP and though it's maybe getting weak.
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Anyway to check glow plugs or injectors with a scan tool like a duramax or no?
You can buzz test the injectors. But that only tells you the circuit is good.
You can amp draw the glow plugs, but it doesn't tell you which one is bad.. they are dinosaurs so you gotta treat em old school.. check the glow plugs with a good old school test light. Not an led one
catman3126
Ehhh?.... You don't say?
Jul 24, 2012
2,636
NE Oregon
How many miles? depending on how cold it is when he is starting it outside. if the relay has gone bad a 7.3 will start really hard and smoke or not start at all in the 40 deg range. if just a few glow plugs have went bad then that could be the issue. if its higher miles like 200-250k+ might as well do a set of injectors and glow plugs and a relay. world of difference..
catman3126
Jul 24, 2012
2,636
NE Oregon
easy to check if the relay is bad. one of the two bigger posts is hot all the time and when you turn the key on the other once should be hot too if not that's it. its bad. I'd start there before you go after GP's
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
If it's starting in 20-40 degree weather not plugged in the relay is good imo.. most 7.3s won't start at 50 or less with no relay lol.
fast03
1,201
60
Rancho Cucamonga
I have heard of the upper oil gallery being clogged and not being exchanged with engine oil... maybe causing a sticking injector because its dirty
hetzler_l33
Jan 4, 2017
29
The great Tuscaloosa, Alabama
Just an idea for if nothing else works, knew a guy who had trouble with his truck cranking after it sat for a few hours and he replaced his harness that feeds the GPs. That solved his problem but then again I'm not sure if he checked the GPs since they were replaced not too long before that. Like I said, just a backup idea if you try everything else
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
I know the valve cover gaskets gave ALOT of trouble as the wiring harness for the glow plugs and injectors is part of the gasket. Over time the gaskets break down, oil gets into the wires, and breaks the insulation down and the glow plugs lose current.
WVRigrat05
Wound for sound
Jan 1, 2011
3,081
I told him to check the relay to start. And dump a qt of two stroke oil and 100 gal treatment of fuel cleaner and see what it does and go from there.
I'll let you know what we find out.
kiwilml
454
It might be stiction. The HPOP injectors get wierd with cold fuel and oil...
If I remember correctly there was an article in diesel power mag a year or two back about some shop running some special additive in the oil that helped with cold starts.. I think I would try find some more info on this and try that.. Could be the whole problem?
onebaddmaxxx
1,212
Cecil County Md
Dumping additive in the fuel side isn't going to help the oil side is what has trouble.
The glowplugs can be tested to see if they work properly through the UVCH (under valve cover harness) the outside 2 pins on both sides of plug are for glow plugs. Take a voltmeter ohm between battery ground and each of those pins. Spec is 0-6.0 ohms. Anymore than that they are no good
Buts likely the injectors.
skintback
Take this one to church
Mar 5, 2007
919
Florida
REV-X oil treatment
Helps with the morning sickness of the 7.3 and 6.0 helps clean a sticking spool valve in the injectors
gmac32
288
bellville ohio
i use hot shot's secret stiction eliminator in the oil and hot shot secret diesel extreme in the fuel. The stuff works wonders. It sounds like he could have a couple glow plugs bad but I would still highly recommend the hot shot. I work on fords everyday (not by choice) and adding that stuff really makes a difference.
