Anyone 7.3l smart?
Burn Down
Sep 14, 2008
7,092
Boise Idaho
Dumping additive in the fuel side isn't going to help the oil side is what has trouble.
The glowplugs can be tested to see if they work properly through the UVCH (under valve cover harness) the outside 2 pins on both sides of plug are for glow plugs. Take a voltmeter ohm between battery ground and each of those pins. Spec is 0-6.0 ohms. Anymore than that they are no good
Buts likely the injectors.
You mean 0.1-0.6 ohms.
97OBS
Feb 7, 2017
Here's a 7.3 specific checklist:
-switch to 5w40 synthetic
-check FICM voltage
-check glow plug relay and wiring
-try a different fuel source for higher quality diesel (and replace filters regularly)
-Hot Shot's Secret Stiction Eliminator and Diesel Extreme every 6 months
Awenta
4,090
CT
Well I'm going to steal this thread now. I'm also seven three dumb. What's a good tuning option? It's an 01 7.3 van
quinton
1,883
Granbury Tx.
I just have Ts chip. Makes a little difference. But not gonna get much out of these with out some mods.
bigmackmiller
1,046
Kokomo, IN
Get a custom burned TS chip, by one of the reputable power stroke shops or there are a few other tuning options
