LMM: Another build thread, advice?
cafryer
May 5, 2011
1,074
Utah
Clevite bearings. Good valve bridge bolts i use ARP bolts from Mercant, Cut LB7 pistons, and bolt your motor mounts and i think you will be golden.
arneson
Aug 14, 2011
2,133
stoughton, wisconsin
Wow this is confusing me mors and more. Tryin to decide.which way to go for my build and now im confused. Whats fingers do to make his different? So lb7s cut and coated are not for 750-800hp+? Cause thats what im shootin for. Not tryin to derail veetee. Im in same boat as u.
RKTMech
Idiot with a wrench
Aug 18, 2008
936
The Norco's
These threads should all be titled "Another trip to Vegas" cause nobody knows what the future holds :spit: they're all a gamble in this game. Hope you get a good combo and it stays together :thumb:
LWATSON
future trans limpers
Jul 30, 2008
2,587
55
Scotland Neck NC
When you guys refer to cut and coated stockers do you mean with reliefs also? Do they all get reliefs when there cut or is an option?
LBZrcks
Jun 2, 2007
5,297
12
SoCal
Valve reliefs are just an option if you run a bigger cam. You can run a mild cam and not need valve reliefs.
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
I have a set of Socal Mahle cast cut and coated pistons and rings that are brand new that I'll sell for $1800 if someone's interested.
LWATSON
Jul 30, 2008
2,587
55
Scotland Neck NC
Didnt know that, I thought with any aftermarket cam you needed reliefs. Whats the best street cam you can run without reliefs. My opologies to the OP, I hope I'm asking questions that will also help him.
